**• Hardware Platform ** : GPU • DeepStream Version: 6.2.0 • TensorRT Version: 8.2.0 • NVIDIA GPU Driver Version (valid for GPU only): 525.85.12 • Issue Type( bugs): I am running a crowd estimation model (SAS-Net) as pgie. It gives a 360x640 output buffer which is the crowd density over the whole frame. Now, when I try to generate heatmap from this crowd density output, there seems to be persistent values in the buffer, it seems like buffer holds values from the previous frame and is not reset for every frame. So, when i generate the heatmaps , it contains some abnormal pixels which seems similar to the trajectory a person has moved across the frames.
The model was originally trained in pytorch which i then converted to onnx and then to tensorRT engine using deepstream. I have tested pytorch and onnx models on same video and no issue comes. Its only when I run Deepstream, i face this issue. Attaching images for reference:
Now, I am following following logic to process the tensor output :
/* Iterate user metadata in frames to search PGIE's tensor metadata */
for (NvDsMetaList *l_user = frame_meta->frame_user_meta_list;
l_user != NULL; l_user = l_user->next)
NvDsUserMeta *user_meta = (NvDsUserMeta *)l_user->data;
if (user_meta->base_meta.meta_type != NVDSINFER_TENSOR_OUTPUT_META)
continue;
// no of elments in output layer: equal to that in input layer for crowd model
int outLayerElements = 0;
/* convert to tensor metadata */
NvDsInferTensorMeta *meta =
(NvDsInferTensorMeta *)user_meta->user_meta_data;
for (unsigned int i = 0; i < meta->num_output_layers; i++)
NvDsInferLayerInfo *info = &meta->output_layers_info[i];
info->buffer = meta->out_buf_ptrs_host[i];
if (use_device_mem && meta->out_buf_ptrs_dev[i])
CUDA_CHECK(cudaMemset(meta->out_buf_ptrs_host[i], 0, info->inferDims.numElements * 4));
CUDA_CHECK(cudaMemcpy(meta->out_buf_ptrs_host[i], meta->out_buf_ptrs_dev[i],
info->inferDims.numElements * 4, cudaMemcpyDeviceToHost));
CUDA_CHECK(cudaMemset(meta->out_buf_ptrs_dev[i], 0, info->inferDims.numElements * 4));
outLayerElements = info->inferDims.numElements;
//cout<<"-------------------------------------------------------------------------------------"<<endl;
//cout<<"Number of dimensions in the Output Layer - "<<i<<" "<<info->inferDims.numDims<<endl;
//cout<<"Number of channnels = "<<info->inferDims.d[0]<<endl;
//cout<<"Height ="<<info->inferDims.d[1]<<endl;
//cout<<"Width ="<<info->inferDims.d[2]<<endl;
/* Parse output tensor and fill detection results into objectList. */
std::vector<NvDsInferLayerInfo>
outputLayersInfo(meta->output_layers_info,
meta->output_layers_info + meta->num_output_layers);
//store the crowd model output layer buffer in a vector
std::vector<float> crowdBuffer((float*)outputLayersInfo[0].buffer,
(float*)outputLayersInfo[0].buffer + outLayerElements);
I get the crowd output buffer as a 1-D vector in outputLayersInfo[0].buffer which i then store into a vector. Afterwards I translate it from 1-D to 2-D to get the heatmap.
I dumped the heatmaps and noticed that the glitches in the heatmaps followed the trajectory of the moving person’s head. Hence the buffer which I copied has persistent values.
Actually I used it to clear the device(GPU) buffers after doing cudaMemcpy() so that the buffers are reset to 0. I tried removing the cudeMemset() but the issue is still there.
Please do not do this. "meta->out_buf_ptrs_dev[i] is the address of the device memory but not the memory. The gst-nvinfer will handle the device memory internally. Please do not do anything to it.
No I meant after removing that cudaMemSet portion from my code, the issue of persistent buffers is still there. And there is nothing extra i am doing, just cudaMemCpy the buffers from the meta.
