Cryptographic binding between NVIDIA GPU attestation and actual CUDA execution context
We are designing a fail-closed GPU workload verification system using NVIDIA GPU Attestation / NVAT and CUDA.
We need to determine whether NVIDIA provides a supported mechanism that cryptographically binds verified GPU attestation evidence, such as GPU UEID / attestation session / nonce, to the actual CUDA execution context, driver execution capability, or trusted execution channel that performs a specific workload.
Our security requirement is stronger than matching UUIDs or application-provided nonces. An independent verifier must be able to establish that the workload was executed by the same attested GPU/session and was not substituted, proxied, or replayed through another GPU or CUDA context.
We have reviewed NVAT, GPU attestation claims, SPDM / Confidential Computing flows, and CUDA context identifiers such as cuCtxGetCurrent, cuCtxGetDevice, and cuCtxGetId, but we have not found a documented authenticated binding between these layers.
Questions:
  1. Does NVIDIA currently provide such a supported binding primitive or workflow?
  2. If yes, which SDK/API/documentation should be used?
  3. Can the SPDM/trusted channel or Confidential Computing stack provide an equivalent authenticated binding to the executor/CUDA context?
  4. What is the recommended architecture for proving that a specific attested GPU executed a specific CUDA workload?
  5. Does this require H100/H200/Blackwell or a specific driver/runtime/CC mode?
We are specifically interested in the security boundary guaranteed by NVIDIA, not merely device enumeration or correlation by UUID/nonce .
We are waiting for solutions.
Before I answer, to what extent does the Verifier trust the guest VM? Do you absolutely need the GPU to cryptographically sign some portion of the CUDA workload, or is it acceptable for the software running in the guest VM to attest to some portion of the workload?
Hi Steven,
Thank you — that distinction is exactly what we are trying to clarify.
The verifier does not intend to place unconditional trust in the guest VM.
We would be comfortable with software inside the guest VM attesting to the workload if the guest/executor can itself be measured or attested, and if the verifier can establish a trustworthy binding between:
  1. the attested GPU,
  2. the attested/measured guest VM and executor,
  3. the authenticated GPU↔guest/driver channel,
  4. and the specific workload commitment being executed.
In other words, we do not necessarily require the GPU itself to cryptographically sign the CUDA workload if NVIDIA supports an architecture where a measured/attested guest-side executor can provide equivalent assurance without allowing substitution, proxying, or replay through another GPU/session.
The security property we need is:
An independent verifier should be able to establish that workload X was executed through the trusted execution path associated with the attested GPU/session, rather than merely trusting an application statement or matching UUIDs/nonces.
So both of the following would be useful to understand:
  • whether NVIDIA has any GPU-native primitive for this; and
  • if not, whether NVIDIA recommends a compositional design using confidential VM attestation + measured software/executor + SPDM/trusted GPU channel as the supported trust boundary.
If the latter is the intended model, we would especially appreciate guidance on what NVIDIA considers part of the trusted computing base and which APIs/evidence should be used to establish that chain.
Thank you.
I’d treat this as a chain-of-trust problem rather than relying on GPU UUIDs or nonces alone. A possible approach is to combine confidential VM attestation, a measured executor, and an authenticated GPU communication channel, then bind the workload’s hash or commitment to that verified execution path.
The key question is whether NVIDIA provides a supported mechanism to prove that a particular workload ran through the attested GPU session, or whether the assurance must come from combining several attestation layers. It would be useful to clarify which parts of that chain NVIDIA explicitly guarantees and which still rely on trust in the guest software.
Thanks — this is exactly the trust-boundary we are trying to resolve.
In our current design we already have confidential-VM/workload attestation and verified NVIDIA GPU attestation, but we deliberately stop short of claiming execution binding because we cannot yet prove that the measured executor is the exclusive authenticated path into the attested GPU session.
Could you clarify whether NVIDIA provides any supported mechanism — for example through SPDM, confidential-computing session establishment, driver/runtime APIs, or another interface — that allows a measured guest executor to establish an authenticated channel whose identity/session can then be cryptographically bound to a workload commitment?
Specifically, can NVIDIA guarantee any of the following:
  1. that a given authenticated GPU session is tied to one attested GPU instance;
  2. that only the measured/authorized guest executor can submit work over that session;
  3. that another guest process cannot substitute or inject CUDA work into the same trusted path;
  4. that a workload hash or output commitment can be included in, or cryptographically linked to, that session;
  5. which of these properties are guaranteed by NVIDIA hardware/firmware/driver versus relying on guest software isolation?
Even if NVIDIA does not expose a direct “CUDA execution attestation” primitive, knowing the exact guarantees of the authenticated CPU↔GPU channel would let us determine whether a composed chain-of-trust proof is possible without overstating the assurance.
Not NVIDIA, so I can’t speak for what they guarantee, but we run the compositional version of this and publish the bundles, so here is where the boundary sits in practice.
What the GPU evidence gives you: the report the driver fetches over SPDM carries the nonce you pass in, the measurements of the VBIOS and the driver-loaded firmware (checked against NVIDIA’s RIMs), the CC mode, and a signature chaining to NVIDIA’s device identity CA. Nothing in it names a CUDA context, a process or a workload. In multi-GPU Protected PCIe mode each GPU is attested on its own, and the NVSwitch fabric has separate evidence.
How we bind it to a workload: the verifier writes a manifest (image digest, artifact digests, a random challenge). Inside the TDX guest, SHA-512 of the manifest goes into the TD quote’s REPORTDATA and SHA-256 of it is the nonce for the GPU report. The verifier checks the Intel chain, the TCB and that the TD is not in debug mode, then the NVIDIA token claims and the nonce match. It prints MRTD and RTMR0..3; comparing them with a reference image is the relying party’s step, and that comparison is what turns “some TD” into “the TD you expect”. Put together, it shows the GPU evidence was produced for this challenge, from inside a guest whose measurements you accept.
What it does not give you, which is your points 2 and 3: the CC session that protects the CPU/GPU path is set up by the driver inside the guest, so any process in that guest that can open the device rides the same protected path. Exclusivity of the executor is a property of the measured guest image (single purpose, no shell, nothing else allowed near /dev/nvidia*), so it sits in the guest TCB, not in anything the GPU attests. For point 4, the clean option we know is a second quote when the run ends, with REPORTDATA = H(challenge || output digest). Whether the report you verified is cryptographically tied to the exact SPDM session that carries the bounce buffer keys (your point 1) is not visible from the guest; that part only NVIDIA can answer, and Steven’s question upthread is the right one.
MIT verifier, with a real bundle you can replay offline, if it helps: GitHub - VoltageGPU/voltage-verify: Bind an Intel TDX quote and an NVIDIA GPU attestation to the workload you meant to run, then verify the bundle without trusting the cloud provider. · GitHub
Disclosure: I work on VoltageGPU (we rent Intel TDX VMs with H100/H200).
Julien
