When using the on-demand mode on my GTX1060 Max-Q, CS:GO causes a system hang after few minutes of playing (less than 5min). When going back to the mode NVIDIA (performance mode), the game runs fine.
I am using gamemode to boost performances. It can also enable the GPU while in the on-demand mode by setting the GAMEMODERUNEXEC environment variable. To enable it, I added the following lines in my .profile:
if [ $(prime-select query) == "on-demand" ] ; then
export GAMEMODERUNEXEC="env __NV_PRIME_RENDER_OFFLOAD=1 env __GLX_VENDOR_LIBRARY_NAME=nvidia env __VK_LAYER_NV_optimus=NVIDIA_only"
fi
EDIT: Disabling gamemode doesn’t change anything, the system still freezes.
CS:GO is the only game doing this. I would report it to Valve but I doubt a game could cause a full system hang, so my guess is the problem is related the the driver. I tried disabling the Steam overlay but nothing changed.
The bug happens both on 470 and 495 drivers.
Is anyone else experiencing this issue? What can I do to fix this or to send a bug report to the right place?
You’re running it with “nojoy” option, how do you expect to have fun?
Joking aside, please run nvidia-bug-report.sh as root after a freeze and attach the resulting nvidia-bug-report.log.gz file to your post.
Damn I’ve been doing it wrong the whole time!
Thanks for your response! I updated the main post. In case I wasn’t clear, when I say system hang, I mean the whole screen freezes, sound stops, fans slow down, and nothing responds so I must hard reboot the machine. So the report I uploaded is from a hard reboot after the freeze.
on freezes. Though I don’t know whether this is the reason for the freezes or just a symptom. Did you run a different distro before where this would not happen?
I never used the on-demand for CS:GO before because I had an external monitor attached (which only works in nvidia mode), and I never tried a different distro on this computer.
Don’t know, there wasn’t much info to be found and I still don’t know if this is the reason for the freezes or only an additional message in case of freezes, like said.
I tried with the kernel 5.13 from linux-image-generic-hwe-20.04-edge with corresponding nvidia drivers (linux-modules-nvidia-495-generic-hwe-20.04-edge), and the problem still occurs.
