I’m trying to capture an image with the following setup:
- csi 4 lane ar0231 sensor
- GMSL2 SerDes to CSI-2 interface
- Xavier running r31.1 release
- have camera continually sending pattern data that I confirm is being sent via scope
- raw 12 bayer pattern GRBG
- sudo v4l2-compliance -d /dev/video0
compliance test passes - trying to capture single image with command:
v4l2-ctl -d /dev/video0 -w --verbose --set-fmt-video=width=1928,height=1208,pixelformat=BA12 --set-ctrl=sensor_mode=0 --stream-mmap --stream-count=1 --set-ctrl bypass_mode=0 --stream-to=ar0231.raw
I get the following errors below. I can actually get the v4l2-ctl call to return and put data into a file if I run the following command first:
sudo sh -c ‘echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked’
That command appears to be critical but I don’t know why. What is it doing? and do I really need to be setting that? or must I have some other setting wrong? I can’t find any documentation about this.
Here is the error case:
nvidia@jetson-0423518031491:~$ [ 117.486751] tegra194-vi5 15c10000.vi: vi capture dequeue status failed
[ 117.518732] tegra194-vi5 15c10000.vi: vi capture dequeue status failed
[ 117.550587] tegra194-vi5 15c10000.vi: vi capture dequeue status failed
[ 117.568837] tegra194-vi5 15c10000.vi: channel error, resetting the channel
[ 117.582546] tegra194-vi5 15c10000.vi: vi capture dequeue status failed
[ 117.582972] tegra194-vi5 15c10000.vi: channel error, resetting the channel
[ 117.614522] tegra194-vi5 15c10000.vi: vi capture dequeue status failed
[ 117.615341] tegra194-vi5 15c10000.vi: channel error, resetting the channel
[ 117.646449] tegra194-vi5 15c10000.vi: vi capture dequeue status failed
[ 117.646720] ------------[ cut here ]------------
[ 117.646826] WARNING: CPU: 3 PID: 7927 at /home/kurt/pro/nvidia/L4T_R31.1/kernel/kernel-4.9/drivers/media/v4l2-core/videobuf2-core.c:899 vb2_buffer_done+0x1f0/0x230
[ 117.647028] tegra194-vi5 15c10000.vi: channel error, resetting the channel
[ 117.647491] —[ end trace 13f1b1ecd6fdc2e7 ]—
[ 117.678374] tegra194-vi5 15c10000.vi: vi capture dequeue status failed
[ 117.647197] Modules linked in: bnep fuse nvs_bmi160 nvs bluedroid_pm ip_tables x_tables
[ 117.647249] CPU: 3 PID: 7927 Comm: vi-output, mtc_ Not tainted 4.9.108 #37
[ 117.647252] Hardware name: jetson-xavier (DT)
[ 117.647255] task: ffffffc3e9892a00 task.stack: ffffffc3563e4000
[ 117.647261] PC is at vb2_buffer_done+0x1f0/0x230
[ 117.647266] LR is at free_ring_buffers+0x6c/0x140
[ 117.647281] pc : [] lr : [] pstate: 20c00045
[ 117.647287] sp : ffffffc3563e7d00
[ 117.647300] x29: ffffffc3563e7d00 x28: 0000000000000000
[ 117.647316] x27: 0000000000000000 x26: ffffffc3d614aeb8
[ 117.647328] x25: ffffff800da3e000 x24: 431bde82d7b634db
[ 117.647340] x23: 0000000000000007 x22: ffffffc3d614ab48
[ 117.647353] x21: ffffffc3e817f400 x20: ffffffc3e817f400
[ 117.647364] x19: ffffffc3d614a018 x18: 000000000012650b
[ 117.647377] x17: 0000007f9bc85748 x16: 00000000000000b7
[ 117.647411] x15: 0000000000000000 x14: 00000000000000ea
[ 117.647415] x13: 0000000000000000 x12: 0000000000000092
[ 117.647420] x11: 00000000000c0e73 x10: 0000000000000000
[ 117.647427] x9 : 0000000000000400 x8 : 000000000000021a
[ 117.647431] x7 : 0000000000000000 x6 : 000000000000009b
[ 117.647437] x5 : 0000000000000004 x4 : 0000000000000007
[ 117.647441] x3 : 0000000000000003 x2 : ffffffc3ada19118
[ 117.647483] x1 : 0000000000000007 x0 : 0000000000000007
clocks.txt (29.1 KB)
daisy.dts.txt (264 KB)
