I have two cameras connected to the TX2 (port A and port C).
The devices are listed as: /dev/video0 and /dev/video1
I can get the streaming correctly from the camera on the port A. However, when I try to open the camera streaming on the port C, I get this errors on nvcamera-daemon logs
PowerServiceCore:handleRequests: timePassed = 1160
NvViErrorDecode Stream 2.0 failed: ts 584189821152 frame 7 error 2 data 0x004000
62
NvViErrorDecode CaptureError: CsimuxFrameError (2)
NvViErrorDecode See https://wiki.nvidia.com/wmpwiki/index.php/Camera_Debugging/C
aptureError_debugging for more information and links to documents.
CsimuxFrameError_Regular : 0x00400062
Stream ID [ 2: 0]: 2
VPR state from fuse block [ 3]: 0
Frame end (FE) [ 5]: 1
A frame end has been found on a regular mode stream.
CSI_FAULT [ 6]: 1
An FE packet was found and marked with a CSI Error
CSI_CODE [25:20]: 0x4
Check the CSI specification for the meaning. See https://wiki.nvidia.com
/wmpwiki/index.php/Camera_Debugging/CaptureError_debugging#CSI_CODE
captureErrorCallback Stream 2.0 capture 1 failed: ts 584189821152 frame 7 error
2 data 0x00400062
This page is not available https://wiki.nvidia.com/wmpwiki/index.php/Camera_Debugging/CaptureError_debugging
