Hello, I have similar problem as this thread for TX2: https://devtalk.nvidia.com/default/topic/1037057/jetson-tx2/red-screen-with-quot-vid_rend-syncpoint-wait-timeout-quot-/post/5268424/ but the suggested option is not working (service is not even running).
The red screen shows only with resolution 3840x2160, FullHD is ok and when it occurs, I must reboot the whole devkit, stop it in terminal doesn’t work. Camera used is this https://leopardimaging.com/product/li-jetson-kit-imx274-x/, sadly I can’t try it on different monitor, current is Dell S2817Q connected directly to devkit via HDMI so there aren’t any converters.
Pipeline is
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)NV12, framerate=(fraction)30/1' ! autovideosink
and terminal output
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3840 x 2160 FR = 59.999999 fps; Analog Gain range min 1.000000, max 44.400002; Exposure Range min 44000, max 666637000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps; Analog Gain range min 1.000000, max 177.000000; Exposure Range min 58000, max 184611000;
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps; Analog Gain range min 1.000000, max 30.000000; Exposure Range min 57000, max 20480000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps; Analog Gain range min 1.000000, max 177.000000; Exposure Range min 56000, max 666479000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 3840 H = 2160
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
vid_rend: syncpoint wait timeout
'vid_rend: syncpoint wait timeout
'^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:03.558175330
'Setting pipeline to READY ...
'GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL ...
'Freeing pipeline ...
