CSI camera stops working after enabling I2S
Background: I am using a Jetson Nano Dev Kit with an e-CAM24_CUNX camera module through the CSI header. I am also using an Adafruit SPH0645LM4H microphone.
Situation: I recently upgraded from JetPack 4.4.1 to 4.6.1 to test a new camera driver from the vendor. At some point after I got the system back up and running with the updated camera driver, my microphone stopped working. I ran sudo /opt/nvidia/jetson-io/jetson-io.py to reconfigure the 40 pin header for the SPH0645LM4H, rebooted, and verified the microphone was working by executing arecord -D hw:tegrasndt210ref,0 -r 44100 -f S32_LE -c 1 -d 10 test.wav. Everything sounds good, but now my camera doesn’t show up in ls /dev/video*. Also, when I run dmesg after booting, this relevant message pops up: " ar0234 : loading out-of-tree module taints kernel." (ar0234 is the e-con camera).
I tried reinstalling the camera driver, but that didn’t do anything. When I delete the “/boot/tegra210-p3448-0000-p3449-0000-b00-user-custom.dtb” file from and reboot, the camera reappears but the mic doesn’t work again.
Am I doing anything obviously wrong here?
I did notice that on my other board running JetPack 4.4.1, running sudo /opt/nvidia/jetson-io/config-by-hardware.py -n "Adafruit SPH0645LM4H" saves the configuration to “/boot/tegra210-p3448-0000-p3449-0000-b00-adafruit-sph0645lm4h.dtb”
But running the same command on JetPack 4.6.1 saves the configuration to “/boot/tegra210-p3448-0000-p3449-0000-b00-user-custom.dtb”
Could that be the issue?
I would suggest consult with E-CON to get the dtbo file for jetson-io to enable the camera.
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3261/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/hw_setup_jetson_io.html#wwpID0E03B0HA
Just updating this thread: I consulted with E-CON per @ShaneCCC’s suggestion and they were able to provide an updated driver with the correct GPIO pin configuration to work with the SPH0645LM4H microphone.
