Hi
we have two 3840*2160 camera connect to max96717 ---- max96712 ----orin。
so the data rate is 1.8G。
when i config max96712 data rate below1.5G(such as 1.4G), i can rev images, but fps do not normal.
when the data rate config to 1.8G clk 900M, i can not rev images。
orin side i have already config serdes_pix_clk_hz = “600000000”;
the trace log below:
root@orin-desktop:/home/orin# cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 113/113 #P:8
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/4:1-2928 [004] .... 3422.553571: rtcpu_string: tstamp:107682264698 id:0x04010000 str:"VM0 deactivating."
v4l2-ctl-3061 [001] .... 3470.959381: tegra_channel_open: vi-output, ar0820 30-0010
v4l2-ctl-3061 [001] .... 3470.973446: tegra_channel_set_power: ar0820 30-0010 : 0x1
v4l2-ctl-3061 [001] .... 3470.973455: camera_common_s_power: status : 0x1
v4l2-ctl-3061 [004] .... 3470.975244: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3061 [004] .... 3470.975249: csi_s_power: enable : 0x1
v4l2-ctl-3061 [005] .... 3470.977353: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt c4
v4l2-ctl-3061 [005] .... 3470.984362: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-3061 [005] .... 3470.986203: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-3061 [005] .... 3470.986206: csi_s_stream: enable : 0x1
v4l2-ctl-3061 [005] .... 3470.990881: tegra_channel_set_stream: ar0820 30-0010 : 0x1
kworker/4:1-2928 [004] .... 3470.997034: rtcpu_string: tstamp:109196601073 id:0x04010000 str:"VM0 activating."
kworker/4:1-2928 [004] .... 3470.997036: rtcpu_nvcsi_intr: tstamp:109196957989 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997037: rtcpu_nvcsi_intr: tstamp:109196958435 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997037: rtcpu_nvcsi_intr: tstamp:109196958877 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997037: rtcpu_nvcsi_intr: tstamp:109196959322 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997037: rtcpu_nvcsi_intr: tstamp:109196959768 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997037: rtcpu_nvcsi_intr: tstamp:109196960210 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997038: rtcpu_nvcsi_intr: tstamp:109196961101 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997038: rtcpu_nvcsi_intr: tstamp:109196961545 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997038: rtcpu_nvcsi_intr: tstamp:109196961989 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997038: rtcpu_nvcsi_intr: tstamp:109196962435 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997038: rtcpu_nvcsi_intr: tstamp:109196964213 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997039: rtcpu_nvcsi_intr: tstamp:109196964659 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997039: rtcpu_nvcsi_intr: tstamp:109196965104 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997039: rtcpu_nvcsi_intr: tstamp:109196965546 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997039: rtcpu_nvcsi_intr: tstamp:109196965992 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997039: rtcpu_nvcsi_intr: tstamp:109196966437 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997039: rtcpu_nvcsi_intr: tstamp:109196966883 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997040: rtcpu_nvcsi_intr: tstamp:109196967326 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997040: rtcpu_nvcsi_intr: tstamp:109196967771 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997040: rtcpu_nvcsi_intr: tstamp:109196968216 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997040: rtcpu_nvcsi_intr: tstamp:109196968661 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997040: rtcpu_nvcsi_intr: tstamp:109196969104 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997040: rtcpu_nvcsi_intr: tstamp:109196969550 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997041: rtcpu_nvcsi_intr: tstamp:109196969995 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997041: rtcpu_nvcsi_intr: tstamp:109196970441 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997041: rtcpu_nvcsi_intr: tstamp:109196970883 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997041: rtcpu_nvcsi_intr: tstamp:109196971329 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/4:1-2928 [004] .... 3470.997041: rtcpu_nvcsi_intr: tstamp:109196972002 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x01c00000
kworker/4:1-2928 [004] .... 3470.997041: rtcpu_nvcsi_intr: tstamp:109196972002 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00c00000
kworker/4:1-2928 [004] .... 3470.997043: rtcpu_vinotify_error: tstamp:109197025765 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:3 vi_tstamp:3494304802784 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3470.997043: rtcpu_vinotify_error: tstamp:109197059561 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:2 vi_tstamp:3494305884320 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3470.997044: rtcpu_vinotify_event: tstamp:109197080979 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3494296163712 data:0x379d580010000000
kworker/4:1-2928 [004] .... 3470.997044: rtcpu_vinotify_event: tstamp:109197081114 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3494296170176 data:0x0000000031000001
kworker/4:1-2928 [004] .... 3470.997044: rtcpu_vinotify_event: tstamp:109197081268 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3494296215520 data:0x379d550010000000
kworker/4:1-2928 [004] .... 3470.997044: rtcpu_vinotify_event: tstamp:109197081402 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3494296222048 data:0x0000000031000002
kworker/4:1-2928 [004] .... 3470.997044: rtcpu_vinotify_event: tstamp:109197081554 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:3 vi_tstamp:3494304802784 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3470.997045: rtcpu_vinotify_event: tstamp:109197081691 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:2 vi_tstamp:3494305884320 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3471.053039: rtcpu_vinotify_error: tstamp:109197177412 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:0 vi_tstamp:3494309655520 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3471.053041: rtcpu_vinotify_event: tstamp:109197419087 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:0 vi_tstamp:3494309655520 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3471.053041: rtcpu_vinotify_error: tstamp:109197810680 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:0 vi_tstamp:3494329920160 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3471.053042: rtcpu_vinotify_error: tstamp:109197835585 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:2 vi_tstamp:3494330717120 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3471.053042: rtcpu_vinotify_event: tstamp:109198095135 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:0 vi_tstamp:3494329920160 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3471.053042: rtcpu_vinotify_event: tstamp:109198095296 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:2 vi_tstamp:3494330717120 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3471.109033: rtcpu_vinotify_error: tstamp:109198921582 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:3494365468768 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3471.109033: rtcpu_vinotify_event: tstamp:109199109352 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:3494365468768 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3471.389044: rtcpu_vinotify_error: tstamp:109208248097 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:3 vi_tstamp:3494663917472 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3471.389048: rtcpu_vinotify_event: tstamp:109208574579 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:3 vi_tstamp:3494663917472 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3471.729036: rtcpu_vinotify_error: tstamp:109219582942 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:3 vi_tstamp:3495026632512 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3471.729041: rtcpu_vinotify_event: tstamp:109219730009 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:3 vi_tstamp:3495026632512 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3472.297044: rtcpu_vinotify_error: tstamp:109237456848 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:2 vi_tstamp:3495598597472 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3472.297048: rtcpu_vinotify_event: tstamp:109237646412 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:2 vi_tstamp:3495598597472 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3472.469033: rtcpu_vinotify_error: tstamp:109242981071 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:1 vi_tstamp:3495775372736 data:0x0000000000000001
kworker/4:1-2928 [004] .... 3472.469037: rtcpu_vinotify_event: tstamp:109243055129 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:1 vi_tstamp:3495775372736 data:0x0000000000000001
vi-output, ar08-3063 [002] … 3473.697635: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt c4
kworker/4:1-2928 [004] … 3473.713001: rtcpu_vinotify_error: tstamp:109281848155 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:0 vi_tstamp:3497019117632 data:0x0000000000000001
kworker/4:1-2928 [004] … 3473.713003: rtcpu_vinotify_event: tstamp:109281848763 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3497019117024 data:0x379d580010000000
kworker/4:1-2928 [004] … 3473.713003: rtcpu_vinotify_event: tstamp:109281848903 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:0 vi_tstamp:3497019117632 data:0x0000000000000001
kworker/4:1-2928 [004] … 3473.713003: rtcpu_vinotify_error: tstamp:109281852992 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:3 vi_tstamp:3497019274144 data:0x0000000000000001
kworker/4:1-2928 [004] … 3473.769009: rtcpu_vinotify_event: tstamp:109282166788 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3497019142752 data:0x0000000031000001
kworker/4:1-2928 [004] … 3473.769012: rtcpu_vinotify_event: tstamp:109282166923 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3497019208832 data:0x379d550010000000
kworker/4:1-2928 [004] … 3473.769012: rtcpu_vinotify_event: tstamp:109282167089 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3497019215424 data:0x0000000031000002
kworker/4:1-2928 [004] … 3473.769013: rtcpu_vinotify_event: tstamp:109282167220 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:3 vi_tstamp:3497019274144 data:0x0000000000000001
kworker/4:1-2928 [004] … 3473.769014: rtcpu_vinotify_error: tstamp:109282178523 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:2 vi_tstamp:3497029691136 data:0x0000000000000001
kworker/4:1-2928 [004] … 3473.769015: rtcpu_vinotify_event: tstamp:109282504881 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:2 vi_tstamp:3497029691136 data:0x0000000000000001
kworker/4:1-2928 [004] … 3473.769015: rtcpu_vinotify_error: tstamp:109282712623 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:0 vi_tstamp:3497046782336 data:0x0000000000000001
kworker/4:1-2928 [004] … 3473.769015: rtcpu_vinotify_event: tstamp:109282842835 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:0 vi_tstamp:3497046782336 data:0x0000000000000001
kworker/4:1-2928 [004] … 3473.769016: rtcpu_vinotify_error: tstamp:109282993683 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:2 vi_tstamp:3497055776224 data:0x0000000000000001
kworker/4:1-2928 [004] … 3473.769016: rtcpu_vinotify_event: tstamp:109283180931 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:2 vi_tstamp:3497055776224 data:0x0000000000000001
kworker/4:1-2928 [004] … 3473.881153: rtcpu_vinotify_error: tstamp:109286846674 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:2 vi_tstamp:3497179072032 data:0x0000000000000001
kworker/4:1-2928 [004] … 3473.881157: rtcpu_vinotify_event: tstamp:109286899447 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:2 vi_tstamp:3497179072032 data:0x0000000000000001
kworker/4:1-2928 [004] … 3474.217159: rtcpu_vinotify_error: tstamp:109297441517 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:3497518106976 data:0x0000000000000001
kworker/4:1-2928 [004] … 3474.217163: rtcpu_vinotify_event: tstamp:109297716895 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:3497518106976 data:0x0000000000000001
kworker/4:1-2928 [004] … 3474.329158: rtcpu_vinotify_error: tstamp:109300503819 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:3 vi_tstamp:3497616100384 data:0x0000000000000001
kworker/4:1-2928 [004] … 3474.329162: rtcpu_vinotify_event: tstamp:109300759291 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:3 vi_tstamp:3497616100384 data:0x0000000000000001
kworker/4:1-2928 [004] … 3474.665191: rtcpu_vinotify_error: tstamp:109311333910 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:1 vi_tstamp:3497962663456 data:0x0000000000000001
kworker/4:1-2928 [004] … 3474.665195: rtcpu_vinotify_event: tstamp:109311576598 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:1 vi_tstamp:3497962663456 data:0x0000000000000001
kworker/4:1-2928 [004] … 3475.337149: rtcpu_vinotify_error: tstamp:109332044640 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:3 vi_tstamp:3498625406816 data:0x0000000000000001
kworker/4:1-2928 [004] … 3475.337153: rtcpu_vinotify_event: tstamp:109332197285 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:3 vi_tstamp:3498625406816 data:0x0000000000000001
vi-output, ar08-3063 [002] … 3476.513500: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt c4
kworker/4:1-2928 [004] … 3476.540967: rtcpu_vinotify_event: tstamp:109369845473 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3499834978976 data:0x379d580010000000
kworker/4:1-2928 [004] … 3476.540969: rtcpu_vinotify_event: tstamp:109369845608 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3499834985440 data:0x0000000031000001
kworker/4:1-2928 [004] … 3476.540970: rtcpu_vinotify_event: tstamp:109369845761 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3499835031136 data:0x379d550010000000
kworker/4:1-2928 [004] … 3476.540970: rtcpu_vinotify_event: tstamp:109369845892 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:3499835037696 data:0x0000000031000002
kworker/4:1-2928 [004] … 3476.540972: rtcpu_vinotify_error: tstamp:109369914174 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:3 vi_tstamp:3499837231968 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.540973: rtcpu_vinotify_error: tstamp:109370074720 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:0 vi_tstamp:3499842369280 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.540973: rtcpu_vinotify_error: tstamp:109370123186 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:3499843920448 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.540973: rtcpu_vinotify_event: tstamp:109370159795 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:3 vi_tstamp:3499837231968 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.540973: rtcpu_vinotify_event: tstamp:109370159926 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:0 vi_tstamp:3499842369280 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.540973: rtcpu_vinotify_event: tstamp:109370160077 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:3499843920448 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.600969: rtcpu_vinotify_error: tstamp:109370921450 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:2 vi_tstamp:3499869464736 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.600970: rtcpu_vinotify_error: tstamp:109371102446 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:0 vi_tstamp:3499875256704 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.600971: rtcpu_vinotify_event: tstamp:109371173811 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:2 vi_tstamp:3499869464736 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.600971: rtcpu_vinotify_event: tstamp:109371173964 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:0 vi_tstamp:3499875256704 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.656991: rtcpu_vinotify_error: tstamp:109372296507 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:2 vi_tstamp:3499913466432 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.656995: rtcpu_vinotify_event: tstamp:109372525999 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:2 vi_tstamp:3499913466432 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.656996: rtcpu_vinotify_error: tstamp:109373390497 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:3 vi_tstamp:3499948474272 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.656996: rtcpu_vinotify_event: tstamp:109373540206 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x02 frame:3 vi_tstamp:3499948474272 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.712991: rtcpu_vinotify_error: tstamp:109375762150 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:2 vi_tstamp:3500024367200 data:0x0000000000000001
kworker/4:1-2928 [004] … 3476.768973: rtcpu_vinotify_event: tstamp:109375906498 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x03 frame:2 vi_tstamp:3500024367200 data:0x0000000000000001
kworker/4:1-2928 [004] … 3478.057114: rtcpu_vinotify_error: tstamp:109416914115 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x01 frame:0 vi_tstamp:3501341230016 data:0x0000000000000001
kworker/4:1-2928 [004] … 3478.057119: rtcpu_vinotify_event: tstamp:109417147910 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x01 frame:0 vi_tstamp:3501341230016 data:0x0000000000000001
