Csi error
I collected 6 videos, and when CSI0 failed to collect data, I closed the CSI0 lane. When I tried to collect CSI0 again, I couldn’t collect the CSI data. However, when I turned off CSI1-5, it was normal to collect CSI0 again. Is this the influence of the VI channel? It’s still a driver issue.
hello wf1,
may I know which Jetpack release version you’re working with.
please also share the test pipeline, and the error logs for reference, thanks
YUV camera 1280*1024@25hz
5061aac3e8e5bbbb95df49af6da60dec_346778b13ea2d4f237d748087b55ee7155a2b87f_2_690x394
version R35.3.1
hello wf1,
is it always CSI0 failed to capture frames with 6-cam use-case?
Not necessarily, and I have found that if one of them makes an error, it is necessary to exit all collections. Re collection is possible, normal collection
hello wf1,
could you please share your test pipeline or command-line, and how you terminate one of them.
