I disable the firewall as below mentioned,and use command ‘sudo ./flash.sh -r jetson-orin-nano-devkit-super mmcblk0p1‘ to flash, after flash the system is not work. How can i make the system normal?
https://forums.developer.nvidia.com/t/r36-3-how-to-disable-firewall/299132
The log is below:
Jetson System firmware version 36.4.4-gcid-41062509 date 2025-06-16T15:25:51+00:
00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
......L4TLauncher: Attempting Recovery Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
��debugfs initialized
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.148-tegra (gts@gts-T14-Gen-3) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils))
[ 0.000000] Machine model: NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x26d82f198 TPMFinalLog=0x25e3f0000 SMBIOS=0xffff0000 SMBIOS 3.0=0x26d220000 MEMATTR=0x26708c018 ESRT=0x267112c98 TPMEventLog=0
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x0000000267112c98 to 0x0000000267112cd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000024a000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000277ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x271306800-0x271308fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000277ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000bdffffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000025e224fff]
[ 0.000000] node 0: [mem 0x000000025e225000-0x000000025e3fffff]
[ 0.000000] node 0: [mem 0x000000025e400000-0x000000025e40afff]
[ 0.000000] node 0: [mem 0x000000025e40b000-0x000000025e40bfff]
[ 0.000000] node 0: [mem 0x000000025e40c000-0x000000026b8effff]
[ 0.000000] node 0: [mem 0x000000026b8f0000-0x000000026d82ffff]
[ 0.000000] node 0: [mem 0x000000026d830000-0x0000000271dfffff]
[ 0.000000] node 0: [mem 0x0000000271e00000-0x0000000271ffffff]
[ 0.000000] node 0: [mem 0x0000000272000000-0x000000027259ffff]
[ 0.000000] node 0: [mem 0x0000000272f00000-0x0000000272ffffff]
[ 0.000000] node 0: [mem 0x0000000276000000-0x0000000277ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000277ffffff]
[ 0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patcmod /lg kmodules/5el e
.148-tegr.00000pdates/drlt ive1 zone/ether mobilalt group68/ing68.ko Total pages:be: ERROR56
oul 0.000000] Pol 'r8168': Noec format[ .00ror0] Ker
command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 bl_prof_d
[ 0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 7510404K/8133248K available (19840K kernel code, 4434K rwdata, 10668K rodata, 8320K init, 529K bss, 360700K reserved, 262144K cma-r)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000347] Console: colour dummy device 80x25
[ 0.000408] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000414] pid_max: default: 32768 minimum: 301
[ 0.000449] LSM: Security Framework initializing
[ 0.000473] Yama: becoming mindful.
[ 0.000490] SELinux: Initializing.
[ 0.000568] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000586] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001682] rcu: Hierarchical SRCU implementation.
[ 0.004232] Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[ 0.004485] Remapping and enabling EFI services.
[ 0.005263] smp: Bringing up secondary CPUs ...
[ 0.005740] Detected PIPT I-cache on CPU1
[ 0.005780] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.005801] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.006240] Detected PIPT I-cache on CPU2
[ 0.006250] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006264] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006657] Detected PIPT I-cache on CPU3
[ 0.006668] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006680] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.009119] Detected PIPT I-cache on CPU4
[ 0.009147] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[ 0.009173] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.009650] Detected PIPT I-cache on CPU5
[ 0.009661] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[ 0.009675] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.009733] smp: Brought up 1 node, 6 CPUs
[ 0.009737] SMP: Total of 6 processors activated.
[ 0.009740] CPU features: detected: 32-bit EL0 Support
[ 0.009742] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.009744] CPU features: detected: Common not Private translations
[ 0.009745] CPU features: detected: CRC32 instructions
[ 0.009745] CPU features: detected: Data cache clean to Point of Persistence
[ 0.009746] CPU features: detected: Generic authentication (architected algorithm)
[ 0.009748] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.009749] CPU features: detected: LSE atomic instructions
[ 0.009749] CPU features: detected: Privileged Access Never
[ 0.009750] CPU features: detected: RAS Extension Support
[ 0.009753] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.047984] CPU: All CPU(s) started at EL2
[ 0.051103] devtmpfs: initialized
[ 0.069012] KASLR enabled
[ 0.069202] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.069228] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.074227] pinctrl core: initialized pinctrl subsystem
[ 0.075244] SMBIOS 3.6.0 present.
[ 0.075256] DMI: NVIDIA NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super/Jetson, BIOS 36.4.4-gcid-41062509 06/16/2025
[ 0.075792] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.077477] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.077605] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.077695] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.077792] audit: initializing netlink subsys (disabled)
[ 0.077932] audit: type=2000 audit(0.076:1): state=initialized audit_enabled=0 res=1
[ 0.079609] thermal_sys: Registered thermal governor 'step_wise'
[ 0.079613] thermal_sys: Registered thermal governor 'user_space'
[ 0.079615] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.083218] cpuidle: using governor menu
[ 0.083409] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.083496] ASID allocator initialised with 32768 entries
[ 0.085481] Serial: AMBA PL011 UART driver
[ 0.096144] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[ 0.107121] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.116216] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.116224] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.116225] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.116226] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.117177] cryptd: max_cpu_qlen set to 1000
[ 0.118814] ACPI: Interpreter disabled.
[ 0.120167] VDD_1V8_AO: supplied by VDD_5V0_SYS
[ 0.120346] VDD_3V3_AO: supplied by VDD_5V0_SYS
[ 0.120569] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[ 0.121054] iommu: Default domain type: Translated
[ 0.121062] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.121367] SCSI subsystem initialized
[ 0.121665] vgaarb: loaded
[ 0.121830] usbcore: registered new interface driver usbfs
[ 0.121864] usbcore: registered new interface driver hub
[ 0.121881] usbcore: registered new device driver usb
[ 0.122317] pps_core: LinuxPPS API ver. 1 registered
[ 0.122322] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.122329] PTP clock support registered
[ 0.122398] EDAC MC: Ver: 3.0.0
[ 0.123327] Registered efivars operations
[ 0.123885] FPGA manager framework
[ 0.123951] Advanced Linux Sound Architecture Driver Initialized.
[ 0.124500] Bluetooth: Core ver 2.22
[ 0.124533] NET: Registered PF_BLUETOOTH protocol family
[ 0.124537] Bluetooth: HCI device and connection manager initialized
[ 0.124546] Bluetooth: HCI socket layer initialized
[ 0.124553] Bluetooth: L2CAP socket layer initialized
[ 0.124574] Bluetooth: SCO socket layer initialized
[ 0.124976] clocksource: Switched to clocksource arch_sys_counter
[ 0.158869] VFS: Disk quotas dquot_6.6.0
[ 0.158942] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.159161] pnp: PnP ACPI: disabled
[ 0.162253] NET: Registered PF_INET protocol family
[ 0.162557] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.164082] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.164179] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.164194] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.164290] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.165709] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.165878] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.165910] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.166078] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.166435] RPC: Registered named UNIX socket transport module.
[ 0.166439] RPC: Registered udp transport module.
[ 0.166439] RPC: Registered tcp transport module.
[ 0.166441] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.166453] PCI: CLS 0 bytes, default 64
[ 0.166709] Unpacking initramfs...
[ 0.167628] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.167879] kvm [1]: IPA Size Limit: 48 bits
[ 0.167917] kvm [1]: GICv3: no GICV resource entry
[ 0.167924] kvm [1]: disabling GICv2 emulation
[ 0.167952] kvm [1]: GIC system register CPU interface enabled
[ 0.168030] kvm [1]: vgic interrupt IRQ9
[ 0.168182] kvm [1]: VHE mode initialized successfully
[ 0.170676] Initialise system trusted keyrings
[ 0.170720] Key type blacklist registered
[ 0.170823] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[ 0.174645] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.175036] NFS: Registering the id_resolver key type
[ 0.175058] Key type id_resolver registered
[ 0.175062] Key type id_legacy registered
[ 0.175109] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.175125] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.175148] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.175332] 9p: Installing v9fs 9p2000 file system support
[ 0.175965] integrity: Platform Keyring initialized
[ 0.189047] Key type asymmetric registered
[ 0.189051] Asymmetric key parser 'x509' registered
[ 0.189127] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.189136] io scheduler mq-deadline registered
[ 0.189144] io scheduler kyber registered
[ 0.199724] EINJ: ACPI disabled.
[ 0.212193] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.213941] SuperH (H)SCI(F) driver initialized
[ 0.214309] msm_serial: driver initialized
[ 0.215028] printk: console [ttyTCU0] enabled
[ 0.216009] arm-smmu 8000000.iommu: probing hardware configuration...
[ 0.216015] arm-smmu 8000000.iommu: SMMUv2 with:
dri 0.216023] arm-smmod800000moduleu: stage.15 1 traa/kation
vers/p[ .21tegra/6] phy-te8001940.iommu.ko age 2 translation
[ 0.216029] arm-smmu 8000000.iommu: neinsd tranib/modtioules/5.15n
8-t 0a/kern4] arm-smel/mu 800ver0.ici/u: troreallem matcwc/pciith 12e-t8 ra194.ksteroups
[ 0.216039] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.216050] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.216054] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.216055] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.217117] arm-smmu 10000000.iommu: probing hardware configuration...
[ 0.217120] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.217122] arm-smmu 10000000.iommu: stage 1 translation
[ 0.217123] arm-smmu 10000000.iommu: stage 2 translation
[ 0.217124] arm-smmu 10000000.iommu: nested translation
[ 0.217127] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.217131] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.217136] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.217137] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.217138] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.217538] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.217541] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.217542] arm-smmu 12000000.iommu: stage 1 translation
[ 0.217543] arm-smmu 12000000.iommu: stage 2 translation
[ 0.217545] arm-smmu 12000000.iommu: nested translation
[ 0.217548] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.217549] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.217564] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.217566] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.217567] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.224806] loop: module loaded
[ 0.225546] megasas: 07.717.02.00-rc1
[ 0.229631] tun: Universal TUN/TAP device driver, 1.6
[ 0.230263] thunder_xcv, ver 1.0
[ 0.230287] thunder_bgx, ver 1.0
[ 0.230306] nicpf, ver 1.0
[ 0.231161] hclge is initializing
[ 0.231189] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.231194] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.231243] e1000: Intel(R) PRO/1000 Network Driver
[ 0.231249] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.231284] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.231291] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.231319] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.231325] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.231346] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.231351] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.231584] sky2: driver version 1.30
[ 0.232300] VFIO - User Level meta-driver version: 0.3
[ 0.233793] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.233819] ehci-pci: EHCI PCI platform driver
[ 0.233846] ehci-platform: EHCI generic platform driver
[ 0.233926] ehci-orion: EHCI orion driver
[ 0.233992] ehci-exynos: EHCI Exynos driver
[ 0.234053] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.234065] ohci-pci: OHCI PCI platform driver
[ 0.234090] ohci-platform: OHCI generic platform driver
[ 0.234165] ohci-exynos: OHCI Exynos driver
[ 0.234598] usbcore: registered new interface driver usb-storage
[ 0.236441] i2c_dev: i2c /dev entries driver
[ 0.237779] pps pps0: new PPS source ktimer
[ 0.237789] pps pps0: ktimer PPS source registered
[ 0.237796] pps_ldisc: PPS line discipline registered
[ 0.239920] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.241693] sdhci: Secure Digital Host Controller Interface driver
[ 0.241698] sdhci: Copyright(c) Pierre Ossman
[ 0.242173] Synopsys Designware Multimedia Card Interface Driver
[ 0.242771] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.243861] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.244805] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.245386] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.246751] tegra-bpmp bpmp: firmware: e941463f35523d12ee54-da583751bbf
[ 0.541425] Freeing initrd memory: 21212K
[ 4.070929] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 4.070956] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 4.070960] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 4.071454] hid: raw HID events driver (C) Jiri Kosina
[ 4.071895] usbcore: registered new interface driver usbhid
[ 4.071901] usbhid: USB HID core driver
[ 4.076873] optee: probing for conduit method.
[ 4.076927] optee: revision 4.2 (d78bc5fa)
[ 4.137647] optee: dynamic shared memory is enabled
[ 4.137927] optee: initialized driver
[ 4.141851] usbcore: registered new interface driver snd-usb-audio
[ 4.143621] NET: Registered PF_PACKET protocol family
[ 4.144776] Bluetooth: RFCOMM TTY layer initialized
[ 4.144818] Bluetooth: RFCOMM socket layer initialized
[ 4.144856] Bluetooth: RFCOMM ver 1.11
[ 4.145223] 9pnet: Installing 9P2000 support
[ 4.145375] Key type dns_resolver registered
[ 4.146909] printk: console [ttyTCU0]: printing thread started
[ 4.147049] Loading compiled-in X.509 certificates
[ 4.185003] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 4.187164] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 4.189510] serial-tegra 3100000.serial: RX in PIO mode
[ 4.189514] serial-tegra 3100000.serial: TX in PIO mode
[ 4.189655] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 4.191776] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[ 4.197172] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.197185] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.197876] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 4.205315] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 4.211987] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 4.217083] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 4.222339] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[ 4.223241] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 4.252331] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1773000 KHz, changing to: 1728000 KHz
[ 4.257770] tegra-xusb 3610000.usb: Adding to iommu group 2
[ 4.273439] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 4.273448] tegra-xusb 3610000.usb: xHCI Host Controller
[ 4.273462] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 4.274201] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[ 4.274223] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[ 4.274361] tegra-xusb 3610000.usb: xHCI Host Controller
[ 4.274366] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 4.274370] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.274811] hub 1-0:1.0: USB hub found
[ 4.274825] hub 1-0:1.0: 4 ports detected
[ 4.275113] hub 2-0:1.0: USB hub found
[ 4.275123] hub 2-0:1.0: 4 ports detected
[ 4.276223] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 4.276578] irq: IRQ228: trimming hierarchy from :bus@0:pmc@c360000
[ 4.276629] irq: IRQ229: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 4.276688] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.279155] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 4.317792] ALSA device list:
[ 4.317797] No soundcards found.
[ 4.365849] irq: IRQ230: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 4.366216] mmc0: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 4.367272] Freeing unused kernel memory: 8320K
[ 4.367367] Run /init as init process
[ 4.383637] Root device found: initrd
[ 4.394594] r8168: disagrees about version of symbol module_layout
[ 4.401811] Mount initrd as rootfs and enter recovery mode
[ 4.613152] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.783180] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 4.783561] mmcblk0: mmc0:aaaa SD64G 59.5 GiB
[ 4.784823] hub 1-2:1.0: USB hub found
[ 4.786115] hub 1-2:1.0: 4 ports detected
[ 4.789582] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 4.898007] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[ 4.949410] hub 2-1:1.0: USB hub found
[ 4.951779] hub 2-1:1.0: 4 ports detected
[ 5.057153] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 5.434047] tegra194-pcie 140a0000.pcie: Adding to iommu group 4
[ 5.541466] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ranges:
[ 5.541488] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[ 5.541495] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff -> 0x0040000000
[ 5.541498] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff -> 0x002a100000
[ 5.541802] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[ 5.541804] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 5.648979] tegra194-pcie 140a0000.pcie: Link up
[ 5.650467] tegra194-pcie 140a0000.pcie: Link up
[ 5.650523] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 5.650528] pci_bus 0008:00: root bus resource [io 0x0000-0xfffff] (bus address [0x2a100000-0x2a1fffff])
[ 5.650531] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 5.650533] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 5.650534] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 5.650583] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 5.650745] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 5.654149] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 5.654307] pci 0008:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 5.654309] pci 0008:01:00.0: reg 0x10: [io size 0x0100]
[ 5.654492] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 5.654610] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 5.655603] pci 0008:01:00.0: supports D1 D2
[ 5.655605] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 5.667750] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 5.667753] pci 0008:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 5.667757] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 5.667850] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 5.667943] pci 0008:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 5.667972] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 5.667976] pci 0008:00:00.0: bridge window [io 0x1000-0x1fff]
[ 5.667979] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 5.668067] pcieport 0008:00:00.0: Adding to iommu group 4
[ 5.668154] pcieport 0008:00:00.0: PME: Signaling with IRQ 189
[ 5.668647] pcieport 0008:00:00.0: AER: enabled with IRQ 189
[ 5.668927] tegra194-pcie 14100000.pcie: Adding to iommu group 5
[ 5.669875] irq: IRQ231: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 5.672016] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[ 5.672039] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 5.672047] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 5.672054] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 5.672532] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[ 5.672536] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 5.777149] tegra194-pcie 14100000.pcie: Link up
[ 5.779846] tegra194-pcie 14100000.pcie: Link up
[ 5.779899] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 5.779903] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 5.779906] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 5.779909] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 5.779911] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 5.779957] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 5.780127] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 5.783232] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 5.783404] pci 0001:01:00.0: reg 0x10: [io 0x100000-0x1000ff]
[ 5.783606] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 5.784662] pci 0001:01:00.0: supports D1 D2
[ 5.784664] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 5.799752] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 5.799756] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
[ 5.799759] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 5.799862] pci 0001:01:00.0: BAR 0: assigned [io 0x100000-0x1000ff]
[ 5.799892] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 5.799895] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
[ 5.799899] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 5.799983] pcieport 0001:00:00.0: Adding to iommu group 5
[ 5.800060] pcieport 0001:00:00.0: PME: Signaling with IRQ 191
[ 5.800363] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[ 5.800643] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 5.802090] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[ 5.802103] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 5.802110] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 5.802114] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 5.802414] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[ 5.802416] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 5.909160] tegra194-pcie 14160000.pcie: Link up
[ 5.909934] tegra194-pcie 14160000.pcie: Link up
[ 5.909981] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 5.909984] pci_bus 0004:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x36100000-0x361fffff])
[ 5.909987] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 5.909990] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 5.909992] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 5.910034] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 5.910185] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 5.913282] pci 0004:01:00.0: [144d:a80a] type 00 class 0x010802
[ 5.913476] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 5.915363] pci 0004:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0004:00:00.0 (capable of 63.012 Gb/s with 16.0 )
[ 5.927717] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 5.927721] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 5.927806] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 5.927811] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 5.927890] pcieport 0004:00:00.0: Adding to iommu group 6
[ 5.927962] pcieport 0004:00:00.0: PME: Signaling with IRQ 193
[ 5.928269] pcieport 0004:00:00.0: AER: enabled with IRQ 193
[ 5.928503] tegra194-pcie 141e0000.pcie: Adding to iommu group 7
[ 5.929668] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[ 5.929681] tegra194-pcie 141e0000.pcie: MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[ 5.929689] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
[ 5.929692] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
[ 5.930002] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[ 5.930005] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 7.039028] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 8.040819] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 8.040870] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 8.040874] pci_bus 0007:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3e100000-0x3e1fffff])
[ 8.040877] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.040880] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 8.040882] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff pref]
[ 8.040924] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 8.041092] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 8.046515] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 8.046595] pcieport 0007:00:00.0: Adding to iommu group 7
[ 8.046669] pcieport 0007:00:00.0: PME: Signaling with IRQ 195
[ 8.046978] pcieport 0007:00:00.0: AER: enabled with IRQ 195
[ 8.047267] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 8.047405] pci 0007:00:00.0: Removing from iommu group 7
[ 8.047422] pci_bus 0007:00: busn_res: [bus 00-ff] is released
insmod /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme-core.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme.ko
[ 8.061155] nvme 0004:01:00.0: Adding to iommu group 6
[ 8.061527] nvme nvme0: pci function 0004:01:00.0
[ 8.061832] nvme 0004:01:00.0: enmod /lib/vice (module0 -> 00028-t[ egr.06ernel/9] nvme nvmeherShu/tegrawn /tegraeout s-bpto 10 secl.kondo s
8.068500] nvme nvme0: 6/0/0 default/read/poll queues
insmod /lib/modules/5.15.148-tegra/kernel/drivers/pwm/pwm-tegra.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/hwmon/pwm-fan.ko
Checking whether device /dev/mmcblk?p1 exist
[ 8.103946] Finding OLoowork dg fon OTA woernrk directory on th
evice(s): /dev/mmcblk0p1
[ 8.113640] mount /dev/mmcblk0p1 /mnt
[ 8.166612] EXT4-fs (mmcblk0p1): recovery complete
[ 8.167401] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 8.169087] is_boot_part_for_disk_enc /dev/mmcblk0p1 /mnt
[ 8.199955] The mounted /dev/mmcblk0p1 is boot partition, try locating rootfs partition and mount it...
[ 8.201313] mount_rootfs_partition /dev/mmcblk0p1 /mnt
[ 8.398628] Failed to get the rootfs partition with PARTUUID=3952f69d-4a76-4a3e-9Checkia14whether d210evi138ce /de[ d?1 exist5]
Failed to run "moutn_rootfs_partition /dev/mmcblk0p1 /mnt"
[ 8.401152] Failed to run "mount_ota_work_partition /dev/mmcblk0p1 /mnt"
Device /dev/sd?1 does not exist
Checking whether device /dev/nvme?n1p1 exist
Device /dev/nvme?n1p1 does not exist
[ 8.407063] Finding OTA work dir on internal storage device
[ 8.408323] mount /dev/mmcblk0 /mnt
mount: /mnt: /dev/mmcblk0 already mounted or mount point busy.
[ 8.426865] Failed to mount /dev/mmcblk0 on the /mnt
[ 8.428079] Failed to run "mount_ota_work_partition /dev/mmcblk0 /mnt"
[ 8.429326] OTA work directory is not found on internal and external storage devices
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.1#
