We are developing custom hardware which incorporates the NX module. I am using the following dtsi file as a template for the imx304 camera:
tegra194-p2822-0000-camera-imx390-a00.dtsi
In the above dtsi file are clock definitions:
clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>,
<&bpmp_clks TEGRA194_CLK_EXTPERIPH1>;
clock-names = “extperiph1”, “pllp_grtba”;
mclk = “extperiph1”;
My questions is how does TEGRA194_CLK_EXTPERIPH1 relate or get assigned to the the CSIn_CLK_x pin of the NX module? Are the clocks hardcoded to the pins? If so, how would i find this clock to pin mapping.
If you can provide an explanation or documentation about the relationship of that clock to the CSI clock pins, and how to change it, that would be appreciated.
Thanks,
Malcolm
