i have an issue when trying to use camera on CSI2 (tegra_sinterface = “serial_c”;), On NX TX2, with CSI0 (tegra_sinterface = “serial_a”;) it works.
bellow debug traces:
CSI0 → OK
root@jetson-tx2-nx:~# v4l2-ctl -d /dev/video1 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1
[ 664.802372] ov5647 10-0036: Set Mode 0
<[ 665.788588] ov5647 10-0036: StopStreaming
v4l2-ctl-444 [004] .... 544.568519: tegra_channel_open: vi-output, ov5647 9-0036
v4l2-ctl-444 [000] .... 544.569847: tegra_channel_set_power: ov5647 9-0036 : 0x1
v4l2-ctl-444 [000] .... 544.569856: camera_common_s_power: status : 0x1
v4l2-ctl-444 [000] .... 544.573997: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
v4l2-ctl-444 [000] .... 544.574000: csi_s_power: enable : 0x1
v4l2-ctl-444 [004] .... 544.586243: tegra_channel_capture_setup: vnc_id 0 W 2592 H 1944 fmt 20
vi-output, ov56-445 [005] .... 544.586357: tegra_channel_set_stream: enable : 0x1
vi-output, ov56-445 [000] .... 544.587497: tegra_channel_set_stream: 150c0000.nvcsi--2 : 0x1
vi-output, ov56-445 [000] .... 544.587499: csi_s_stream: enable : 0x1
vi-output, ov56-445 [000] .... 544.587527: tegra_channel_set_stream: ov5647 9-0036 : 0x1
kworker/4:1-56 [004] .... 544.609349: rtos_queue_peek_from_isr_failed: tstamp:17249388663 queue:0x0b4b4940
kworker/4:1-56 [004] .... 544.609351: rtcpu_start: tstamp:17249389910
kworker/4:1-56 [004] .... 544.609353: rtos_queue_send_from_isr_failed: tstamp:17249396816 queue:0x0b4a7698
kworker/4:1-56 [004] .... 544.609354: rtos_queue_send_from_isr_failed: tstamp:17249396922 queue:0x0b4ab1a8
kworker/4:1-56 [004] .... 544.609354: rtos_queue_send_from_isr_failed: tstamp:17249397030 queue:0x0b4acdd8
kworker/4:1-56 [004] .... 544.609355: rtos_queue_send_from_isr_failed: tstamp:17249397139 queue:0x0b4af718
kworker/4:1-56 [004] .... 544.609356: rtos_queue_send_from_isr_failed: tstamp:17249397265 queue:0x0b4b04d8
kworker/4:1-56 [004] .... 544.609357: rtos_queue_send_from_isr_failed: tstamp:17249397368 queue:0x0b4b1298
kworker/4:1-56 [004] .... 544.609358: rtos_queue_send_from_isr_failed: tstamp:17249397472 queue:0x0b4b2058
kworker/4:1-56 [004] .... 544.609359: rtos_queue_send_failed: tstamp:17249397917 queue:0x0b4a7698
kworker/4:1-56 [004] .... 544.609360: rtos_queue_send_from_isr_failed: tstamp:17249399521 queue:0x0b4a7698
kworker/4:1-56 [004] .... 544.609361: rtos_queue_send_from_isr_failed: tstamp:17249399627 queue:0x0b4ab1a8
kworker/4:1-56 [004] .... 544.609362: rtos_queue_send_from_isr_failed: tstamp:17249399732 queue:0x0b4acdd8
kworker/4:1-56 [004] .... 544.609362: rtos_queue_send_from_isr_failed: tstamp:17249399841 queue:0x0b4af718
kworker/4:1-56 [004] .... 544.609363: rtos_queue_send_from_isr_failed: tstamp:17249399946 queue:0x0b4b04d8
kworker/4:1-56 [004] .... 544.609364: rtos_queue_send_from_isr_failed: tstamp:17249400051 queue:0x0b4b1298
kworker/4:1-56 [004] .... 544.609365: rtos_queue_send_from_isr_failed: tstamp:17249400156 queue:0x0b4b2058
kworker/4:1-56 [004] .... 544.609365: rtos_queue_send_failed: tstamp:17249401095 queue:0x0b4a7698
vi-output, ov56-445 [004] .... 544.678573: tegra_channel_capture_frame: sof:544.660181408
kworker/4:1-56 [004] .... 544.711347: rtcpu_vinotify_event: tstamp:17252285618 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:17252285091 data:0x00000001
kworker/4:1-56 [004] .... 544.711348: rtcpu_vinotify_event: tstamp:17252285790 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:17252285102 data:0x00000000
kworker/4:1-56 [004] .... 544.711349: rtcpu_vinotify_event: tstamp:17252288133 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:2 vi_tstamp:17252287755 data:0x08000000
vi-output, ov56-445 [004] .... 544.742529: tegra_channel_capture_frame: sof:544.724149216
kworker/4:1-56 [004] .... 544.762351: rtcpu_vinotify_event: tstamp:17254260316 tag:CHANSEL_PXL_EOF channel:0x00 frame:2 vi_tstamp:17254259614 data:0x07970002
kworker/4:1-56 [004] .... 544.762353: rtcpu_vinotify_event: tstamp:17254260435 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:17254259669 data:0x00000000
kworker/4:1-56 [004] .... 544.762354: rtcpu_vinotify_event: tstamp:17254284603 tag:CHANSEL_PXL_SOF channel:0x00 frame:3 vi_tstamp:17254284085 data:0x00000001
kworker/4:1-56 [004] .... 544.762354: rtcpu_vinotify_event: tstamp:17254284770 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:17254284096 data:0x00000000
kworker/4:1-56 [004] .... 544.762355: rtcpu_vinotify_event: tstamp:17254286750 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:3 vi_tstamp:17254286374 data:0x08000000
kworker/4:1-56 [004] .... 544.762357: rtos_queue_peek_from_isr_failed: tstamp:17254388978 queue:0x0b4b4940
vi-output, ov56-445 [004] .... 544.806504: tegra_channel_capture_frame: sof:544.788117024
kworker/4:1-56 [004] .... 544.813345: rtcpu_vinotify_event: tstamp:17256259309 tag:CHANSEL_PXL_EOF channel:0x00 frame:3 vi_tstamp:17256258608 data:0x07970002
kworker/4:1-56 [004] .... 544.813347: rtcpu_vinotify_event: tstamp:17256259433 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:17256258662 data:0x00000000
kworker/4:1-56 [004] .... 544.813347: rtcpu_vinotify_event: tstamp:17256283596 tag:CHANSEL_PXL_SOF channel:0x00 frame:4 vi_tstamp:17256283079 data:0x00000001
kworker/4:1-56 [004] .... 544.813348: rtcpu_vinotify_event: tstamp:17256283760 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:17256283090 data:0x00000000
kworker/4:1-56 [004] .... 544.813349: rtcpu_vinotify_event: tstamp:17256285970 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:4 vi_tstamp:17256285594 data:0x08000000
vi-output, ov56-445 [004] .... 544.870466: tegra_channel_capture_frame: sof:544.852084864
kworker/4:1-56 [004] .... 544.915345: rtcpu_vinotify_event: tstamp:17258258301 tag:CHANSEL_PXL_EOF channel:0x00 frame:4 vi_tstamp:17258257602 data:0x07970002
kworker/4:1-56 [004] .... 544.915348: rtcpu_vinotify_event: tstamp:17258258416 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:17258257656 data:0x00000000
kworker/4:1-56 [004] .... 544.915348: rtcpu_vinotify_event: tstamp:17258282590 tag:CHANSEL_PXL_SOF channel:0x00 frame:5 vi_tstamp:17258282074 data:0x00000001
kworker/4:1-56 [004] .... 544.915349: rtcpu_vinotify_event: tstamp:17258282756 tag:ATOMP_FS channel:0x00 frame:5 vi_tstamp:17258282085 data:0x00000000
kworker/4:1-56 [004] .... 544.915350: rtcpu_vinotify_event: tstamp:17258285256 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:5 vi_tstamp:17258284880 data:0x08000000
kworker/4:1-56 [004] .... 544.915351: rtos_queue_peek_from_isr_failed: tstamp:17259388966 queue:0x0b4b4940
kworker/4:1-56 [004] .... 544.966344: rtcpu_vinotify_event: tstamp:17260257301 tag:CHANSEL_PXL_EOF channel:0x00 frame:5 vi_tstamp:17260256597 data:0x07970002
kworker/4:1-56 [004] .... 544.966345: rtcpu_vinotify_event: tstamp:17260257423 tag:ATOMP_FE channel:0x00 frame:5 vi_tstamp:17260256651 data:0x00000000
kworker/4:1-56 [004] .... 544.966346: rtcpu_vinotify_event: tstamp:17260281586 tag:CHANSEL_PXL_SOF channel:0x00 frame:6 vi_tstamp:17260281068 data:0x00000001
kworker/4:1-56 [004] .... 544.966347: rtcpu_vinotify_event: tstamp:17260281749 tag:ATOMP_FS channel:0x00 frame:6 vi_tstamp:17260281079 data:0x00000000
v4l2-ctl-444 [004] .... 544.997633: tegra_channel_capture_done: eof:0.0
CSI2 → KO
v4l2-ctl-447 [004] .... 590.334499: tegra_channel_open: vi-output, ov5647 10-0036
v4l2-ctl-447 [000] .... 590.335819: tegra_channel_set_power: ov5647 10-0036 : 0x1
v4l2-ctl-447 [000] .... 590.335828: camera_common_s_power: status : 0x1
v4l2-ctl-447 [000] .... 590.339975: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-447 [000] .... 590.339977: csi_s_power: enable : 0x1
v4l2-ctl-447 [004] .... 590.352141: tegra_channel_capture_setup: vnc_id 0 W 2592 H 1944 fmt 20
vi-output, ov56-448 [005] .... 590.352239: tegra_channel_set_stream: enable : 0x1
vi-output, ov56-448 [005] .... 590.353416: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, ov56-448 [005] .... 590.353418: csi_s_stream: enable : 0x1
vi-output, ov56-448 [005] .... 590.353447: tegra_channel_set_stream: ov5647 10-0036 : 0x1
kworker/4:1-56 [004] .... 590.356345: rtos_queue_peek_from_isr_failed: tstamp:18679572972 queue:0x0b4b4940
kworker/4:1-56 [004] .... 590.356347: rtcpu_start: tstamp:18679574016
kworker/4:1-56 [004] .... 590.356349: rtos_queue_send_from_isr_failed: tstamp:18679580787 queue:0x0b4a7698
kworker/4:1-56 [004] .... 590.356350: rtos_queue_send_from_isr_failed: tstamp:18679580893 queue:0x0b4ab1a8
kworker/4:1-56 [004] .... 590.356350: rtos_queue_send_from_isr_failed: tstamp:18679581002 queue:0x0b4acdd8
kworker/4:1-56 [004] .... 590.356351: rtos_queue_send_from_isr_failed: tstamp:18679581114 queue:0x0b4af718
kworker/4:1-56 [004] .... 590.356352: rtos_queue_send_from_isr_failed: tstamp:18679581217 queue:0x0b4b04d8
kworker/4:1-56 [004] .... 590.356353: rtos_queue_send_from_isr_failed: tstamp:18679581321 queue:0x0b4b1298
kworker/4:1-56 [004] .... 590.356354: rtos_queue_send_from_isr_failed: tstamp:18679581426 queue:0x0b4b2058
kworker/4:1-56 [004] .... 590.356355: rtos_queue_send_failed: tstamp:18679581918 queue:0x0b4a7698
kworker/4:1-56 [004] .... 590.356356: rtos_queue_send_from_isr_failed: tstamp:18679583864 queue:0x0b4a7698
kworker/4:1-56 [004] .... 590.356357: rtos_queue_send_from_isr_failed: tstamp:18679583979 queue:0x0b4ab1a8
kworker/4:1-56 [004] .... 590.356357: rtos_queue_send_from_isr_failed: tstamp:18679584084 queue:0x0b4acdd8
kworker/4:1-56 [004] .... 590.356358: rtos_queue_send_from_isr_failed: tstamp:18679584193 queue:0x0b4af718
kworker/4:1-56 [004] .... 590.356359: rtos_queue_send_from_isr_failed: tstamp:18679584298 queue:0x0b4b04d8
kworker/4:1-56 [004] .... 590.356360: rtos_queue_send_from_isr_failed: tstamp:18679584402 queue:0x0b4b1298
kworker/4:1-56 [004] .... 590.356361: rtos_queue_send_from_isr_failed: tstamp:18679584506 queue:0x0b4b2058
kworker/4:1-56 [004] .... 590.356361: rtos_queue_send_failed: tstamp:18679585421 queue:0x0b4a7698
vi-output, ov56-448 [000] .... 590.444807: tegra_channel_capture_frame: sof:590.426413984
kworker/4:1-56 [004] .... 590.458346: rtcpu_vinotify_event: tstamp:18682480382 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:18682479857 data:0x00000001
kworker/4:1-56 [004] .... 590.458348: rtcpu_vinotify_event: tstamp:18682480548 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:18682479869 data:0x00000000
kworker/4:1-56 [004] .... 590.458348: rtcpu_vinotify_event: tstamp:18682482974 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:2 vi_tstamp:18682482593 data:0x08000000
vi-output, ov56-448 [004] .... 590.508764: tegra_channel_capture_frame: sof:590.490380256
kworker/4:1-56 [004] .... 590.509347: rtcpu_vinotify_event: tstamp:18684455036 tag:CHANSEL_PXL_EOF channel:0x00 frame:2 vi_tstamp:18684454332 data:0x07970002
kworker/4:1-56 [004] .... 590.509348: rtcpu_vinotify_event: tstamp:18684455171 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:18684454387 data:0x00000000
kworker/4:1-56 [004] .... 590.509349: rtcpu_vinotify_event: tstamp:18684479318 tag:CHANSEL_PXL_SOF channel:0x00 frame:3 vi_tstamp:18684478803 data:0x00000001
kworker/4:1-56 [004] .... 590.509350: rtcpu_vinotify_event: tstamp:18684479481 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:18684478814 data:0x00000000
kworker/4:1-56 [004] .... 590.509351: rtcpu_vinotify_event: tstamp:18684481588 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:3 vi_tstamp:18684481213 data:0x08000000
kworker/4:1-56 [004] .... 590.560343: rtos_queue_peek_from_isr_failed: tstamp:18684573306 queue:0x0b4b4940
vi-output, ov56-448 [004] .... 590.572732: tegra_channel_capture_frame: sof:590.554346528
kworker/4:1-56 [004] .... 590.611344: rtcpu_vinotify_event: tstamp:18686453985 tag:CHANSEL_PXL_EOF channel:0x00 frame:3 vi_tstamp:18686453277 data:0x07970002
kworker/4:1-56 [004] .... 590.611346: rtcpu_vinotify_event: tstamp:18686454103 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:18686453332 data:0x00000000
kworker/4:1-56 [004] .... 590.611347: rtcpu_vinotify_event: tstamp:18686478268 tag:CHANSEL_PXL_SOF channel:0x00 frame:4 vi_tstamp:18686477749 data:0x00000001
kworker/4:1-56 [004] .... 590.611348: rtcpu_vinotify_event: tstamp:18686478432 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:18686477759 data:0x00000000
kworker/4:1-56 [004] .... 590.611348: rtcpu_vinotify_event: tstamp:18686480609 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:4 vi_tstamp:18686480233 data:0x08000000
vi-output, ov56-448 [004] .... 590.636694: tegra_channel_capture_frame: sof:590.618312736
kworker/4:1-56 [004] .... 590.662343: rtcpu_vinotify_event: tstamp:18688452921 tag:CHANSEL_PXL_EOF channel:0x00 frame:4 vi_tstamp:18688452222 data:0x07970002
kworker/4:1-56 [004] .... 590.662345: rtcpu_vinotify_event: tstamp:18688453038 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:18688452278 data:0x00000000
kworker/4:1-56 [004] .... 590.662346: rtcpu_vinotify_event: tstamp:18688477212 tag:CHANSEL_PXL_SOF channel:0x00 frame:5 vi_tstamp:18688476693 data:0x00000001
kworker/4:1-56 [004] .... 590.662347: rtcpu_vinotify_event: tstamp:18688477378 tag:ATOMP_FS channel:0x00 frame:5 vi_tstamp:18688476704 data:0x00000000
kworker/4:1-56 [004] .... 590.662347: rtcpu_vinotify_event: tstamp:18688479860 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:5 vi_tstamp:18688479484 data:0x08000000
kworker/4:1-56 [004] .... 590.713343: rtos_queue_peek_from_isr_failed: tstamp:18689573298 queue:0x0b4b4940
kworker/4:1-56 [004] .... 590.713345: rtcpu_vinotify_event: tstamp:18690451869 tag:CHANSEL_PXL_EOF channel:0x00 frame:5 vi_tstamp:18690451169 data:0x07970002
kworker/4:1-56 [004] .... 590.713346: rtcpu_vinotify_event: tstamp:18690451984 tag:ATOMP_FE channel:0x00 frame:5 vi_tstamp:18690451223 data:0x00000000
kworker/4:1-56 [004] .... 590.713347: rtcpu_vinotify_event: tstamp:18690476158 tag:CHANSEL_PXL_SOF channel:0x00 frame:6 vi_tstamp:18690475638 data:0x00000001
kworker/4:1-56 [004] .... 590.713347: rtcpu_vinotify_event: tstamp:18690476323 tag:ATOMP_FS channel:0x00 frame:6 vi_tstamp:18690475650 data:0x00000000
v4l2-ctl-447 [004] .... 590.763851: tegra_channel_capture_done: eof:0.0
i’m using Mate DevKit.
Could explain the changes between CSI0 and CSI2 (2 Lanes).
Regards.
