After modifying the location, updating the device tree, and testing, the problem still persists.
I also checked the port-index configuration in other locations and no further issues were found.
error kernel log:
[ 112.147181] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 512
[ 112.180526] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 512
[ 112.213854] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 512
[ 112.247180] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 512
Try again, kernel log:
[ 247.007311] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 247.007616] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 247.008972] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 247.009216] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 247.009525] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 247.009764] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 247.010387] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 249.567148] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 249.567434] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 249.567970] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 249.568212] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 249.568548] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 249.568786] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 249.569426] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 252.095156] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 252.095456] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 252.096162] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 252.096389] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 252.096698] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 252.096924] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 252.097445] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
