dear sir,
Hardware connection:
Analog Video Input---->Video decode ->MIPI---->nano
camera hardware configuration:
1920X1080@30fps
after modify kernel and bsp,Run as below at terminal:
v4l2-ctl -d /dev/video0 --stream-mmap --stream-count=100 --stream-to=video0.yuv
Kernel error reporting as below:
nvp6188,nvp6188_power_on++
nvp6188,nvp6188_power_on–
vi 54080000.vi: Calibrate csi port 0
nvp6188,nvp6188_s_stream,enable=0
nvp6188,nvp6188_g_input_status
vi 54080000.vi: cil_settingtime was autocalculated
vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
nvp6188,nvp6188_s_stream,enable=1
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 0
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 1
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 2
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 3
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 4
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 7
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 8
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 9
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 10
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 11
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 12
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 13
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 14
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 15
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 16
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 17
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 18
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 19
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 20
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 21
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 22
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 23
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 24
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 25
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 26
vi 54080000.vi: tegra_channel_error_status:error 20022 frame 27
