I am working on CSI2 interfacing of Jetson AGX Xavier with TI RADAR Sensor.
Communication control of RADAR Sensor from Jetson is done with I2C through the 40 pin expansion header and the RADAR sends RAW16 data via the CSI2 ports.
I now wanted to implement the CSI2 data part on the Jetson code to receive this data.
Could anyone let me know where should I start or what should be done on the Jetson side ?
Is it mandatory I modify the device tree or is it possible that I access the v4l2 ioctl user space functions alone for the obtaining the data?
If I were to modify the device tree, what values do I configure for the frame rate , hdr ratio etc…, since I use a RADAR Sensor instead of a camera sensor.( I referred to the imx185 configuration)
