Hi Morganh, I am not allowed to share the images however I tried to use other sample image with low confidence hope you will understand the difference between darkent53 tensorrt and all other network tensorrt inference. I am attaching 2 different images first one is csp darkent53 result and second one is other networks result, please kindly have a look.
Can you share the expected result for above image when you use tao inference
to run inference against the tensorrt engine?
The expected result should same like the second Image that I attached which is the result of resnet18, resnet101 and mobilenet engines.
Suggest you to use tao inference
to run inference against above image and share with the result. Thanks.
