Hi Team,
We observe the mlx5 driver option ct_action_on_nat_conns is not there in the driver code base. But I see the in the below doc, it still pointing to this config. Can you please help me to understand. Is this config is still there or not.
Hi Team,
Hi ramachaitanya.k1,
Thank you for posting your query on NVIDIA Community. Based on internal check, this code was indeed removed. We will work on fixing the documentation to avoid confusion.
However, in order to use the feature/parameter, it is still supported in DOCA 2.9.3 LTS version.
Thanks,
NVEX Networking Technical Support.
