CTRL+ALT+F2 works with HDMI ouput and doesn't works with DP output
while i’m trying to check different color depth of the outputs i ended with black screen and mouse cursor. So i found that CTRL+ALT+F2 supposed to switch to text-based login prompt. It works only with the HDMI output. When i’m using the DP output i just get a message at the monitor that there’s no input signal, meaning that the jetson developer kit doesn’t output any signal.
Is this behavior OK?
How can i enter the text-based login when i’m using DP output?
I’m using Jetson Xavier NX developer kit with Jetpack 4.6.1 (i need this specif Jetpack).
I cannot confirm about it. If we want to dig into the case, then it requires to dig into kernel code.
