cub::DeviceRadixSort output wrong result when number of items larger than 4800
Hi, I try to use cub::DeviceRadixSort with below simply test program:
I found that whenever num_items larger than 4800 (e.g. 4900), the program failed to give correct result.
When num_items is 4800, the output looks like this (which is expected)
However, when num_items is set to 4900, the output array is not work as expected:
#include <cub/cub.cuh>
#include <cstdio>
int main()
    int num_items = 4800;          // e.g., 7
    uint32_t *d_keys_in;         // e.g., [8, 6, 7, 5, 3, 0, 9]
    uint32_t *d_keys_out;        // e.g., [        ...        ]
    uint32_t *d_values_in;       // e.g., [0, 1, 2, 3, 4, 5, 6]
    uint32_t *d_values_out;      // e.g., [        ...        ]
    cudaMallocManaged(&d_keys_in, num_items * sizeof(uint32_t));
    cudaMallocManaged(&d_keys_out, num_items * sizeof(uint32_t));
    cudaMallocManaged(&d_values_in, num_items * sizeof(uint32_t));
    cudaMallocManaged(&d_values_out, num_items * sizeof(uint32_t));
    for(int i = 0; i < num_items; i++)
        d_keys_in[i] = num_items - i;
        d_values_in[i] = i;
    void *d_temp_storage = nullptr;
    size_t temp_storage_bytes = 0;
    cub::DeviceRadixSort::SortPairs(d_temp_storage, temp_storage_bytes, d_keys_in, d_keys_out, d_values_in,
                                    d_values_out, num_items);
    cudaMalloc(&d_temp_storage, temp_storage_bytes);
                                    d_keys_in, d_keys_out, d_values_in, d_values_out, num_items);
    cudaDeviceSynchronize();
    for (int i = 0; i < num_items; i++)
        printf("%d ", d_keys_out[i]);
    printf("\n");
        printf("%d ", d_values_out[i]);
    printf("\n");
    cudaFree(d_keys_in);
    cudaFree(d_keys_out);
    cudaFree(d_values_in);
    cudaFree(d_values_out);
    return 0;
I wonder if I’m using this function in wrong way. My cuda version is 12.6 and nvcc version is 12.5.
Thanks in advance.
The code works correct on my machine.
Add error checking to all cuda api calls and to all cub calls.
Run your code with compute-sanitizer.
I encountered a similar problem. You can try removing the -O3 option.
If there is no bug in the program and the -O3 flag makes a difference, the bug should be reported as compiler bug.
