I am currently using the Aerial testbed, but I encounter the following error when attempting to connect multiple UEs simultaneously. I would like to know what this error means and how to resolve it.
Thank you in advance.
oai-gnb-aerial | UE 757a: dlsch_rounds 18/0/0/0, dlsch_errors 0, pucch0_DTX 0, BLER 0.04783 MCS (1) 0 CCE fail 0
oai-gnb-aerial | UE 757a: ulsch_rounds 43/1/1/1, ulsch_errors 1, ulsch_DTX 4, BLER 0.00985 MCS (0) 0 (Qm 2 deltaMCS 0 dB) NPRB 5 SNR 29.0 dB CCE fail 0
oai-gnb-aerial | UE 757a: MAC: TX 1287 RX 4113 bytes
oai-gnb-aerial | UE 757a: LCID 1: TX 636 RX 1313 bytes
oai-gnb-aerial | UE 757a: LCID 2: TX 0 RX 0 bytes
oai-gnb-aerial | UE 757a: LCID 4: TX 9 RX 448 bytes
oai-gnb-aerial |
oai-gnb-aerial | 2250179.986262 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250179.986265 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250179.986267 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:29.243402 ERR UlPhyDriver21 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:29.243403 ERR UlPhyDriver21 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 506 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:29.243403 ERR UlPhyDriver21 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:29.243405 ERR UlPhyDriver21 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 256.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:29.243412 ERR UlPhyDriver21 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:29.243901 WRN UlPhyDriver04 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 506
nv-cubb | 06:08:29.244901 WRN UlPhyDriver24 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 506
nv-cubb | 06:08:29.245411 WRN UlPhyDriver24 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 506
oai-gnb-aerial | 2250180.066263 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250180.066268 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250180.066269 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:29.323402 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:29.323403 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 24 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:29.323403 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:29.323405 ERR UlPhyDriver04 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 264.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:29.323413 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:29.323901 WRN UlPhyDriver04 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 24
nv-cubb | 06:08:29.324902 WRN UlPhyDriver24 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 24
nv-cubb | 06:08:29.325411 WRN UlPhyDriver31 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 24
oai-gnb-aerial | 2250180.146263 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250180.146269 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250180.146270 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
oai-gnb-aerial | 2250180.226262 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250180.226267 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250180.226268 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:29.403402 ERR UlPhyDriver23 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:29.403403 ERR UlPhyDriver23 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 54 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:29.403403 ERR UlPhyDriver23 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:29.403405 ERR UlPhyDriver23 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 272.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:29.403413 ERR UlPhyDriver23 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:29.403901 WRN UlPhyDriver25 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 54
nv-cubb | 06:08:29.404902 WRN UlPhyDriver21 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 54
nv-cubb | 06:08:29.405411 WRN UlPhyDriver04 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 54
nv-cubb | 06:08:29.483402 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:29.483403 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 84 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:29.483403 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:29.483405 ERR UlPhyDriver05 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 280.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:29.483412 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:29.483901 WRN UlPhyDriver21 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 84
nv-cubb | 06:08:29.484902 WRN UlPhyDriver22 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 84
nv-cubb | 06:08:29.485411 WRN UlPhyDriver04 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 84
oai-gnb-aerial | 2250180.306262 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250180.306266 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250180.306267 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:29.563402 ERR UlPhyDriver24 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:29.563403 ERR UlPhyDriver24 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 114 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:29.563403 ERR UlPhyDriver24 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:29.563405 ERR UlPhyDriver24 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 288.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:29.563411 ERR UlPhyDriver24 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:29.563902 WRN UlPhyDriver22 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 114
nv-cubb | 06:08:29.564901 WRN UlPhyDriver31 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 114
nv-cubb | 06:08:29.565411 WRN UlPhyDriver23 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 114
oai-gnb-aerial | 2250180.386262 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250180.386267 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250180.386268 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:29.643402 ERR UlPhyDriver21 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:29.643403 ERR UlPhyDriver21 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 144 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:29.643403 ERR UlPhyDriver21 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:29.643405 ERR UlPhyDriver21 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 296.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:29.643412 ERR UlPhyDriver21 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:29.643902 WRN UlPhyDriver04 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 144
nv-cubb | 06:08:29.644900 WRN UlPhyDriver24 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 144
nv-cubb | 06:08:29.645412 WRN UlPhyDriver22 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 144
oai-gnb-aerial | 2250180.466259 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250180.466265 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250180.466266 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:29.723402 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:29.723402 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 174 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:29.723403 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:29.723404 ERR UlPhyDriver04 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 304.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:29.723409 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:29.723901 WRN UlPhyDriver22 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 174
nv-cubb | 06:08:29.724901 WRN UlPhyDriver22 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 174
nv-cubb | 06:08:29.725411 WRN UlPhyDriver24 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 174
nv-cubb | 06:08:29.760009 CON timer_thread 0 [SCF.PHY] Cell 0 | DL 0.05 Mbps 56 Slots | UL 0.02 Mbps 44 Slots CRC 0 ( 231) | Tick 170000
oai-gnb-aerial | 2250180.546265 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250180.546269 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250180.546270 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
oai-gnb-aerial | 2250180.626265 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250180.626270 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250180.626272 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:29.803404 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:29.803405 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 204 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:29.803406 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:29.803407 ERR UlPhyDriver05 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 312.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:29.803415 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:29.803901 WRN UlPhyDriver23 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 204
nv-cubb | 06:08:29.804901 WRN UlPhyDriver04 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 204
nv-cubb | 06:08:29.805411 WRN UlPhyDriver04 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 204
nv-cubb | 06:08:29.883404 ERR UlPhyDriver25 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:29.883406 ERR UlPhyDriver25 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 234 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:29.883406 ERR UlPhyDriver25 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:29.883408 ERR UlPhyDriver25 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 320.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:29.883415 ERR UlPhyDriver25 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:29.883901 WRN UlPhyDriver05 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 234
nv-cubb | 06:08:29.884901 WRN UlPhyDriver04 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 234
nv-cubb | 06:08:29.885411 WRN UlPhyDriver04 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 234
oai-gnb-aerial | 2250180.706261 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250180.706266 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250180.706268 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:29.963402 ERR UlPhyDriver25 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:29.963402 ERR UlPhyDriver25 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 264 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:29.963403 ERR UlPhyDriver25 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:29.963404 ERR UlPhyDriver25 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 328.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:29.963411 ERR UlPhyDriver25 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:29.963901 WRN UlPhyDriver05 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 264
nv-cubb | 06:08:29.964901 WRN UlPhyDriver23 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 264
nv-cubb | 06:08:29.965411 WRN UlPhyDriver04 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 264
oai-gnb-aerial | 2250180.786262 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250180.786268 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250180.786269 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:30.043403 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:30.043403 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 294 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:30.043404 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:30.043405 ERR UlPhyDriver04 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 336.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:30.043413 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:30.043901 WRN UlPhyDriver05 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 294
nv-cubb | 06:08:30.044901 WRN UlPhyDriver24 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 294
nv-cubb | 06:08:30.045411 WRN UlPhyDriver31 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 294
oai-gnb-aerial | 2250180.866261 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250180.866267 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250180.866268 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:30.123403 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:30.123404 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 324 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:30.123404 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:30.123405 ERR UlPhyDriver04 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 344.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:30.123411 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:30.123901 WRN UlPhyDriver21 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 324
nv-cubb | 06:08:30.124901 WRN UlPhyDriver05 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 324
nv-cubb | 06:08:30.125411 WRN UlPhyDriver04 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 324
oai-gnb-aerial | 2250180.946260 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250180.946265 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250180.946266 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
oai-gnb-aerial | 2250181.026261 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250181.026267 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250181.026268 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:30.203402 ERR UlPhyDriver23 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:30.203403 ERR UlPhyDriver23 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 354 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:30.203404 ERR UlPhyDriver23 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:30.203405 ERR UlPhyDriver23 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 352.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:30.203410 ERR UlPhyDriver23 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:30.203901 WRN UlPhyDriver31 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 354
nv-cubb | 06:08:30.204901 WRN UlPhyDriver25 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 354
nv-cubb | 06:08:30.205411 WRN UlPhyDriver22 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 354
nv-cubb | 06:08:30.283403 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:30.283404 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 384 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:30.283404 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:30.283405 ERR UlPhyDriver04 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 360.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:30.283411 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:30.283901 WRN UlPhyDriver25 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 384
nv-cubb | 06:08:30.284901 WRN UlPhyDriver25 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 384
nv-cubb | 06:08:30.285411 WRN UlPhyDriver31 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 384
oai-gnb-aerial | 2250181.106260 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250181.106265 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250181.106267 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:30.363402 ERR UlPhyDriver23 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:30.363402 ERR UlPhyDriver23 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 414 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:30.363403 ERR UlPhyDriver23 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:30.363404 ERR UlPhyDriver23 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 368.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:30.363410 ERR UlPhyDriver23 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:30.363901 WRN UlPhyDriver24 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 414
nv-cubb | 06:08:30.364902 WRN UlPhyDriver21 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 414
nv-cubb | 06:08:30.365411 WRN UlPhyDriver05 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 414
oai-gnb-aerial | 2250181.186262 [W] 3799839072: nr_error_ind_cb: [VNF] Received NFAPI_NR_PHY_MSG_TYPE_ERROR_INDICATION idx:1 phy_id:0
oai-gnb-aerial | 2250181.186268 [W] 3799839072: nr_error_ind_cb: [VNF] Previous message 0x81 resulted in an error on the PNF
oai-gnb-aerial | 2250181.186269 [W] 3799839072: nr_error_ind_cb: [VNF] Received error code 0x37 (AERIAL_ERROR_CODE_L1_UL_CPLANE_TX_ERROR)
nv-cubb | 06:08:30.443403 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FH] aerial_fh::send_cplane error
nv-cubb | 06:08:30.443403 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send error for cell index 0,error type 3 Map 444 Abort UL Tasks!
nv-cubb |
nv-cubb | 06:08:30.443404 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Calling ul_tx_error_fn 1491
nv-cubb |
nv-cubb | 06:08:30.443406 ERR UlPhyDriver04 0 [AERIAL_NVIPC_API_EVENT] [SCF.PHY] Send Err.ind for SFN 376.9 cell_id=0 msg_id=0x81 err_code=0x37
nv-cubb | 06:08:30.443412 ERR UlPhyDriver04 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] Task ul_aggr_1_cplane 0 aborted the tasklist for an error
nv-cubb | 06:08:30.443902 WRN UlPhyDriver04 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_orderKernel Task aborted for Slot Map 444
nv-cubb | 06:08:30.444901 WRN UlPhyDriver22 0 [DRV.FUNC_UL] task_work_function_ul_aggr_1_srs Task aborted for Slot Map 444
nv-cubb | 06:08:30.445412 WRN UlPhyDriver25 0 [DRV.FUNC_UL] task_work_function_ul_aggr_3 Task aborted for Slot Map 444
nv-cubb | 06:08:30.448019 ERR msg_processing 0 [AERIAL_NVIPC_API_EVENT] [L2A.TRANSPORT] tx_alloc: NVIPC memory pool is full: transport_id=0
nv-cubb | 06:08:30.449924 ERR UlPhyDriver25 0 [AERIAL_CUPHY_EVENT] [CUPHY] [/opt/nvidia/cuBB/cuPHY/src/cuphy_channels/srs_rx.cpp:297] CUDA driver error invalid argument
nv-cubb | 06:08:30.449994 ERR UlPhyDriver25 0 [AERIAL_CUPHY_EVENT] [CUPHY] CUDA DRIVER EXCEPTION: CUDA driver error: CUDA_ERROR_INVALID_VALUE - invalid argument
nv-cubb | 06:08:30.450003 ERR UlPhyDriver25 0 [AERIAL_CUPHY_API_EVENT] [DRV.SRS] cuphySetupSrshRx returned error 1
nv-cubb | 06:08:30.450006 WRN UlPhyDriver25 0 [DRV.FUNC_UL] SRS setup returned error for Map 447
