I have a skybox composed of 6 texture of 1024x1024. The cubemap works correctly but CodeXL tells me that the cubemap texture takes 110MB. It finds no OpenGL errors.
It takes only 18.4MB on Intel GPU.
This is my code of the cubemap generation:
static const char* names[] = { "/right.", "/left.", "/top.", "/bottom.", "/back.", "/front." };
static const GLenum types[] = {
GL_TEXTURE_CUBE_MAP_POSITIVE_X, GL_TEXTURE_CUBE_MAP_NEGATIVE_X,
GL_TEXTURE_CUBE_MAP_POSITIVE_Y, GL_TEXTURE_CUBE_MAP_NEGATIVE_Y,
GL_TEXTURE_CUBE_MAP_NEGATIVE_Z, GL_TEXTURE_CUBE_MAP_POSITIVE_Z
glGenTextures(1, &_id);
glBindTexture(GL_TEXTURE_CUBE_MAP, _id);
glTexParameteri(GL_TEXTURE_CUBE_MAP, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_CUBE_MAP, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_CUBE_MAP, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_CUBE_MAP, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_CUBE_MAP, GL_TEXTURE_WRAP_R, GL_CLAMP_TO_EDGE);
for (int i = 0; i < 6; ++i)
SDL_Surface *image = loadImage(path + names[i] + extension);
if (image == nullptr)
return false;
int format = image->format->Amask ? GL_RGBA : GL_RGB;
glTexImage2D(types[i], 0, format, image->w, image->h, 0, format, GL_UNSIGNED_BYTE, image->pixels);
SDL_FreeSurface(image);
glBindTexture(GL_TEXTURE_CUBE_MAP, 0);
return true;
I have tested on a GTX 760m with driver 340.52 and a GTX 560ti with driver 340.65.
Stack Overflow : Large memory footprint with OpenGL cubemap - Stack Overflow
