Hi all,
I met a problem of “CUBLAS_STATUS_NOT_SUPPORTED” when i tried to use cublas and multiple GPU in single node. Does anybody know that CUDA 6.0 already support this feature or not? Thanks
Hi all,
cublasXt API is only supported on 64-bit platform : cublasXtCreate will return CUBLAS_STATUS_NOT_SUPPORTED if the platform is not 64-bit
Moreover, with the current licensing, the cublasXt API limits the number of GPus selectable to 2 . cublasXtDeviceSelect will return CUBLAS_STATUS_NOT_SUPPORTED if you select more than 2 Gpus. Please contact Nvidia at cuda@nvidia.com if you want to select more than 2 Gpus.
I’m using cuda 6.0, on a 64bits platform, and I also have that problem of “CUBLAS_STATUS_NOT_SUPPORTED”. Are there other things that can make that error appears ?
