CuBLAS GeMM + Bias
Hi I was trying to get CublasLt MatMul working where I have 2 input matrices and 1 input vector (not matrix).
I cannot seem to get the bias to broadcast for the output matrix.
I’ve tried using the Epilogue + bias pointer and using dissimilar C and D matrices (lead dimension for C set to 0 to facilitate broadcast), both of which did not yield the desired result.
Is there any available code snippet that can demonstrate this capability or is it not possible?
What I want achieve is
D = AxB+C
Where, C is a vector
A,B are matrices
C has the same row length as D but only 1 as the column length
Hardware/Software Details
Jetson Xavier AGX 32 GB
Jetpack 5.1 CUDA 11.4
