[CUBLAS] How to use cublasCgerc_v2?
Hello dear CUDA community,
I am quiet new to CUDA programming, but I a making progress. However, I tried to include the CUBLAS function cublasCgerc_v2 into my program, but the results are more or less total rubbish.
Assume a matrix A with zeros only, a vector x = [1 … 8] and a vector y = [1 … 7]. Everything is complex valued, but with imaginary part 0.
Then, A should be updated with
A = A + x*y**H
Updating the matrix A with cublasCgerc_v2 should give me a matrix:
1     2     3     4     5     6     7
2     4     6     8    10    12    14
3     6     9    12    15    18    21
4     8    12    16    20    24    28
5    10    15    20    25    30    35
6    12    18    24    30    36    42
7    14    21    28    35    42    49
8    16    24    32    40    48    56
However, I a not able to get there.
An excerpt of my code is:
size_t M = 8;
    size_t N = 7;
CudaAECComplex alpha;
    alpha.x = 1.0;
    alpha.y = 0.0;
CudaAECComplex *x,*y,*A;
    CudaAECComplex *dx,*dy,*dA;
x = new CudaAECComplex[M];
    y = new CudaAECComplex[N];
    A = new CudaAECComplex[M*N];
cudaMalloc((void**)&dx, M*sizeof(CudaAECComplex));
    cudaMalloc((void**)&dy, N*sizeof(CudaAECComplex));
    cudaMalloc((void**)&dA, M*N*sizeof(CudaAECComplex));
for(unsigned int i=0;i<M;++i) {
        x[i].x = i+1;
        x[i].y = 0;
    for(unsigned int i=0;i<N;++i) {
        y[i].x = i+1;
        y[i].y = 0;
    for(unsigned int i=0;i<M*N;++i) {
        A[i].x = 0;
        A[i].y = 0;
cudaMemcpy(dx, (void**)x, M*sizeof(CudaAECComplex), cudaMemcpyHostToDevice);
    cudaMemcpy(dy, (void**)y, N*sizeof(CudaAECComplex), cudaMemcpyHostToDevice);
    cudaMemcpy(dA, (void**)A, M*N*sizeof(CudaAECComplex), cudaMemcpyHostToDevice);
size_t status = cublasCgerc_v2(m_cublasHandle, M, N, &alpha, dx, 1, dy, 1, dA, M);
std::cout << "Status: " << status << std::endl;
cudaMemcpy((void**)A, dA, M*N*sizeof(CudaAECComplex), cudaMemcpyDeviceToHost);
        for(unsigned int j=0;j<N;++j) {
            std::cout << "("<< A[i+j*N].x << "," << A[i+j*N].y << ") ";
        std::cout << std::endl;
cudaFree(dx);
    cudaFree(dy);
    cudaFree(dA);
delete[] x;
    delete[] y;
    delete[] A;
I guess there is a very dumb error somewhere in there, but I was not able to locate it. Any help is deepply appreciated.
Best regards, floxtrott
The program above works pretty good in case you have
M=N=8
But I need it for
M!=N
Is there anybody with a helpful hint?
Best regards,
floxtrott
CUBLAS is expecting data in column-major order.
Thanks for your reply. However, the only matrix is initialized with zeros and later printed out in column-major mode. Anyway, it doesn’t matter, since it now works. I am not sure what exactly I changed, but my unit tests runs without complains. Must have been a typo or something.
Greetings and thank you
floxtrott
