CUBLAS libraries, with incorrect permissions
My system is Ubuntu16.04 and after I installed cuda9.0 with nvidia driver 384.90,I indeed can run
cd /NVIDIA_CUDA-9.0_Samples/bin/x86_64/linux/release && ./deviceQuery
without sudo and run properly.
Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GeForce GTX 1080"
  CUDA Driver Version / Runtime Version          9.0 / 9.0
  CUDA Capability Major/Minor version number:    6.1
  Total amount of global memory:                 8106 MBytes (8499691520 bytes)
  (20) Multiprocessors, (128) CUDA Cores/MP:     2560 CUDA Cores
  GPU Max Clock rate:                            1772 MHz (1.77 GHz)
  Memory Clock rate:                             5005 Mhz
  Memory Bus Width:                              256-bit
  L2 Cache Size:                                 2097152 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
  Maximum Layered 1D Texture Size, (num) layers  1D=(32768), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(32768, 32768), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 65536
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  2048
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 2 copy engine(s)
  Run time limit on kernels:                     Yes
  Integrated GPU sharing Host Memory:            No
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Disabled
  Device supports Unified Addressing (UVA):      Yes
  Supports Cooperative Kernel Launch:            Yes
  Supports MultiDevice Co-op Kernel Launch:      Yes
  Device PCI Domain ID / Bus ID / location ID:   0 / 2 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.0, CUDA Runtime Version = 9.0, NumDevs = 1
Result = PASS
However, when I ran “./batchCUBLAS” without sudo ,it failed.
./batchCUBLAS
batchCUBLAS Starting...
GPU Device 0: "GeForce GTX 1080" with compute capability 6.1
CUBLAS initialization failed!
Then I tried to run it with sudo,it passed.
sudo ./batchCUBLAS
==== Running single kernels ====
Testing sgemm
#### args: ta=0 tb=0 m=128 n=128 k=128  alpha = (0xbf800000, -1) beta= (0x40000000, 2)
#### args: lda=128 ldb=128 ldc=128
^^^^ elapsed = 0.00003815 sec  GFLOPS=109.951
@@@@ sgemm test OK
Testing dgemm
#### args: ta=0 tb=0 m=128 n=128 k=128  alpha = (0x0000000000000000, 0) beta= (0x0000000000000000, 0)
^^^^ elapsed = 0.00005102 sec  GFLOPS=82.2065
@@@@ dgemm test OK
 ==== Running N=10 without streams ====
Testing sgemm
#### args: ta=0 tb=0 m=128 n=128 k=128  alpha = (0xbf800000, -1) beta= (0x00000000, 0)
^^^^ elapsed = 0.00005794 sec  GFLOPS=723.958
@@@@ sgemm test OK
Testing dgemm
#### args: ta=0 tb=0 m=128 n=128 k=128  alpha = (0xbff0000000000000, -1) beta= (0x0000000000000000, 0)
^^^^ elapsed = 0.00030494 sec  GFLOPS=137.546
@@@@ dgemm test OK
 ==== Running N=10 with streams ====
Testing sgemm
#### args: ta=0 tb=0 m=128 n=128 k=128  alpha = (0x40000000, 2) beta= (0x40000000, 2)
^^^^ elapsed = 0.00006914 sec  GFLOPS=606.627
@@@@ sgemm test OK
Testing dgemm
^^^^ elapsed = 0.00023317 sec  GFLOPS=179.879
@@@@ dgemm test OK
 ==== Running N=10 batched ====
Testing sgemm
#### args: ta=0 tb=0 m=128 n=128 k=128  alpha = (0x3f800000, 1) beta= (0xbf800000, -1)
^^^^ elapsed = 0.00004792 sec  GFLOPS=875.233
@@@@ sgemm test OK
Testing dgemm
#### args: ta=0 tb=0 m=128 n=128 k=128  alpha = (0xbff0000000000000, -1) beta= (0x4000000000000000, 2)
^^^^ elapsed = 0.00020289 sec  GFLOPS=206.724
@@@@ dgemm test OK
Test Summary
0 error(s)
And when I also test caffe ,tensorflow and pytorch,they all need sudo privillage to run properly.What should I do?
Sounds like you have some files, e.g. perhaps CUBLAS libraries, with incorrect permissions
Ok,I have changed it @txbob
I have the same problem. I solved it by removing the cache files in ~/.nv directory. Found this solution https://discuss.pytorch.org/t/cublas-runtime-error-library-not-initialized-at-data-users-soumith-builder-wheel-pytorch-src-torch-lib-thc-thcgeneral-c-383/1375/5.
