Hi everybody, does any of you know whether the cublas GEMM performance increases in the new toolkit (4.1)?
I can access a server equipped with a GTX580 card. But unfortunately, the OS Fedora 13 is no longer supported under 4.1 toolkit.
So, if you can access a GTX580 or similar Fermi card, can you help to test the SGEMM and DGEMM’s performance to see whether the 4.1 is better than 4.0?
The fact that a Linux version is not supported usually means that it is not tested.
For a Linux version the important things are the gcc and libc versions. Just look for a package for another distro that has the same version of gcc/libc and
it will work.
