CUBLAS slow down after calling CUFFT real to complex transform
Hi all,
I experienced a slow down of CUBLAS gemm in my original code.
When I start to investigate the cause, I found out that it was after an CUFFT call cufftExecR2C (or D2Z) that the slow down happens. However, I did not see this effect after calling complex to complex transform or complex to real transform. A subsequent call of R2C and then C2C can remove the slow down in cublas.
Also, it seems that other cublas routines are also affected after R2C call.
Does anyone have some idea about why this happens?
I have experienced this in both CUDA 4.2 and 5.0
I attached some example code below:
#include <stdlib.h>;
#include <stdio.h>;
#include <sys/time.h>;
#include <cufft.h>;
#include <cublas_v2.h>;
double getTime()
        struct timeval time;
        gettimeofday(&time, NULL);
        double time_ms = (double) time.tv_sec * 1000 + ((double) time.tv_usec / 1000.0);
	return time_ms;
void
runTest( int argc, char** argv)
        int device = 0;
	int N = 12800;
        int M = 4096;
	if(argc >= 2)
                device = atoi(argv[1]);
        cudaSetDevice(device);
        cudaError_t cudastatus;
        float* d_A = NULL;
        cudastatus = cudaMalloc( (void**)&d_A, sizeof(float) * N*M);
        float* d_C = NULL;
        cudastatus = cudaMalloc( (void**)&d_C, sizeof(float) * N * N);
        double begin_time;
        double end_time;
        cublasHandle_t handle;
        cublasCreate(&handle);
        begin_time = getTime();
        float alpha = 1.0;
        float beta = 1.0;
        cublasSgemm(handle, CUBLAS_OP_N,CUBLAS_OP_T,N,N,M,&(alpha),d_A, N, d_A, N, &(beta), d_C, N);
        cudaDeviceSynchronize();
        end_time = getTime();
	printf("cublas original time: %f\n",  end_time - begin_time);
	cufftHandle plan;
	cufftComplex *data ;
	cudaMalloc ( ( void **)&data , sizeof ( cufftComplex ) *( 100) );
	cufftComplex* idata;
        cudaMalloc( (void**)&idata, sizeof(cufftComplex)*100);
        cufftPlan1d(&plan, 100, CUFFT_C2C, 1);
        cufftExecC2C(plan, idata, data, CUFFT_FORWARD);
        cufftDestroy(plan);
        printf("cublas after calling C2C: %f\n", end_time - begin_time);
        cufftPlan1d(&plan, 100, CUFFT_R2C, 1);
        cufftExecR2C(plan, (cufftReal*)idata, data);
        cufftDestroy(plan);
        cudaFree(idata);
        cudaFree(data);
        printf("cublas after calling R2C: %f\n", end_time - begin_time);
        cudaFree(d_A);
        cudaFree(d_C);
        cublasDestroy(handle);
        return;
int
main( int argc, char** argv)
    runTest( argc, argv);
    return 1;
Here is what I got, time in milliseconds:
cublas original time: 1888.888916
cublas after calling C2C: 1889.112061
cublas after calling R2C: 4290.118896
The problem seems to be caused by L1 cache preference change in the cufft call. Since cublas uses no preference and the context has no preference to cache size, cublas uses the last used cache preference, which was set by the cufft.
The evidence is that if I call cudaDeviceSetCacheConfig(cudaFuncCachePreferShared) anywhere before the last cublas call, the speed of the last cublas call went normal.
I think you analysis is entirely correct as a similar interaction was reported recently that involved CURAND. The stickiness of the cache configuration settings is causing trouble in conjunction with libraries. To make sure that all relevant cases are addressed, it would be helpful if you could file a bug for this instance through the registered developer website. Please attach a self-contained repro app. Thank you for your help.
