cuBLAS
docker run --gpus all --name infer …
docker logs -f infer
I See:
I do not know why?
**• Hardware Platform (Jetson / GPU)**Jetson
• DeepStream Version5.0
**• JetPack Version (valid for Jetson only)**4.4
• TensorRT Version7.1.3.0
Can you provide your complete command used in the test? Which Jetson platform is used in the test?
1.docker run -itd --net host --restart=always --name infer -v /etc/localtime:/etc/localtime:ro --gpus all infer-l4t:2022V1
2.NX
Please remove --gpus all.
Did you have cuda installed?
Installed, remove --gpus all ,I can not find nvinfer plugin
Please add --runtime=nvidia to your docker command.
