I have a problem with a cublasGetVector() call and I was wondering if anyone knows why this may be happening.
I have a small kernel doing linear interpolation (I can’t use textures because the data points are non linearly spaced… and binning them will cause too much error.)
For some reason I do not understand I am getting error 11 (CUBLAS_STATUS_MAPPING_ERROR) after the cublasGetVector() call.
The thread “The Official NVIDIA Forums | NVIDIA” has some information but I do not know if this is relevant since when I put a timer around the kernel it takes 6.5ms. (I do have other calls that take more than 20ms to execute and they do not cause this error). I am using a 1024x1024 array for data
I am using Windows Vista 64 and running 2 video cards (one GTX275 for CUDA and a Quadro 570 for the display) with the same driver installed. (Vista would not let me install more than one)
Any help/comment/idea is greatly appreciated!
Thanks in advance!
There was an internal error with my kernel because of addressing(my position array had values beyond the limits of the other arrays). When I put the cutilCheckMsg() after the call, it catch the error. For some reason, when the kernel failed, this was also causing the getvector() call to fail.
