n an H200(or H100), half-precision GEMM returns wrong results with no error when the process runs as an MPS client with CUDA_MPS_ACTIVE_THREAD_PERCENTAGE below 100. cublasLtMatmul returns CUBLAS_STATUS_SUCCESS, there is no Xid, and part of the output matrix is simply never written.
Environment: H200 (132 SMs), driver 580.178.04, cuBLAS 12.6.4.1 / 12.8.3.14 / 13.1.1.3 / 13.4.1.3 / 13.8.1.7. cuBLAS 12.4.5.8 is not affected.
Minimal reproduction (stock PyTorch image, one script):
nvidia-cuda-mps-control -d
docker run --rm --gpus all --ipc=host -v /tmp/nvidia-mps:/tmp/nvidia-mps -v $PWD:/w \
-e CUDA_MPS_ACTIVE_THREAD_PERCENTAGE=14 \
pytorch/pytorch:2.14.1-cuda13.0-cudnn9-runtime python /w/repro_min.py
SM=18 pct=14 torch.float32 MxKxN=16x2048x1000 bad=0/16000
SM=18 pct=14 torch.float16 MxKxN=16x2048x1000 bad=11597/16000 bad_cols=[256..999]
SM=18 pct=14 torch.bfloat16 MxKxN=16x2048x1000 bad=11569/16000 bad_cols=[256..999]
At 12 % (14 SMs) the same script reports bad=0. A C program that calls cublasLtMatmul directly reproduces it without PyTorch or Docker.
Scope
- 66 of the 100 percentages give wrong results (14–22, 28–46, 52–89 %, i.e. 18–28, 36–60, 68–116 SMs). 100 % and no MPS are always correct.
- FP16, BF16 and FP8 (E4M3) are affected; FP32 is not.
- cuDNN is affected too, because it calls
cublasLtMatmulfor half-precision 1×1 convolutions. ResNet and Qwen3-8B produce garbage or non-finite outputs. - Only
algoId=66configurations with 4 or 8 CTAs per cluster fail. Cluster shapes with 1 or 2 CTAs never did. - MIG instances are correct, including the 26-SM and 60-SM profiles whose SM counts fail under MPS. B200 and RTX PRO 6000 Blackwell are correct.
What differs between a correct and a wrong run
For the same algorithm and the same kernel launch, one kernel argument differs: a per-cluster table. In every correct run it is a permutation of the cluster indices (e.g. 0 2 1 3 4 5); in every wrong run it has trailing zeros (e.g. 0 1 2 3 4 0, or 0 0 0 0), so several clusters compute the same part and the rest of the output is left unwritten. cuOccupancyMaxActiveClusters returns different values for an MPS share than for a MIG instance with the same SM count. A plain cluster kernel with the same launch geometry runs correctly under the same MPS share, so the driver’s cluster scheduling itself looks fine.
Questions
- Is this table derived from
cuOccupancyMaxActiveClusters, and are the values returned underCUDA_MPS_ACTIVE_THREAD_PERCENTAGEmeant to be a valid input for it? - Is there a supported way to keep cuBLASLt (and therefore cuDNN) from selecting cluster shapes with more than 2 CTAs?
CUBLASLT_MATMUL_DESC_SM_COUNT_TARGETdoes not help. - Is a fix available or planned?
Full reproduction, per-percentage results, kernel-argument dumps and an LD_PRELOAD workaround that rewrites only the cluster shape:
