Hi all. I’ve got wrong result of this function when I’m using it with Upper nonunit triangular matrix (when I use it with lower triangular matrix evrything is fine).
The coefficient matrix is:
2.45 1.63 2.04
0 0.58 1.15
0 0 0.71
and right side vector is:
11.84 4.62 2.12
But the result I’ve got is:
4.833 8.000 2.999
My call is:
cublasStrsm('l','u','t','n', dimA, 1, 1.0, d_A, dimA, d_S, dimA);
I use ‘t’ because I save matrix in row-major order.
And when I try call it in such way:
cublasStrsm('l','u','n','n', dimA, 1, 1.0, d_A, dimA, d_S, dimA);
I got the same result.
The same situation with cublasStrsv.
So I transpose matrix before cublasStrsm call and then call it in such way:
And I’ve got the right answer!
So obviously in your cublas code you make a mistake and matrix transpose specifier doesn’t make rigth function in those functions :( .
OS version WinXPSP2
Toolkit - 1.0
SDK - 1.0
GPU 8600GT
