I got a similar issue to CUDA 10.1.243 (10.1 update 2) ppc64le run file installation issue on a fresh x86_64 Fedora 32 installation. Any ideas on how to fix it and to get Cuda running?
I tried Cuda versions 10.1 Update 1, 10.1 Update 2, and 10.2 - all fresh downloaded.
What I found in the log file: /var/log/cuda-installer.log
First everything fine with:
[INFO]: cuda-gdb
[INFO]: Successfully created directory: /var/log/nvidia/.uninstallManifests/CUDA_Toolkit_10.2-components/CUDA_Tools_10.2-components/CUDA_Command_Line_Tools_10.2-components/
[INFO]: Successfully created directory: /usr/local/cuda-10.2/extras
[INFO]: Successfully created directory: /usr/local/cuda-10.2/extras/Debugger
[INFO]: Successfully created directory: /usr/local/cuda-10.2/share
Second some Skipping copy:
[INFO]: Installed: /usr/local/cuda-10.2/targets/x86_64-linux/include/thrust/device_new_allocator.h
[INFO]: Installed: /usr/local/cuda-10.2/targets/x86_64-linux/include/thrust/generate.h
[INFO]: Skipping copy. File already exists at: /usr/local/cuda-10.2/targets/x86_64-linux/include/cusolverMg.h
[INFO]: Installed: /usr/local/cuda-10.2/targets/x86_64-linux/include/cublasLt.h
[INFO]: Skipping copy. File already exists at: /usr/local/cuda-10.2/targets/x86_64-linux/include/curand_mtgp32.h
[INFO]: Installed: /usr/local/cuda-10.2/targets/x86_64-linux/include/sm_30_intrinsics.hpp
[INFO]: Skipping copy. File already exists at: /usr/local/cuda-10.2/targets/x86_64-linux/include/nppi_statistics_functions.h
[INFO]: Installed: /usr/local/cuda-10.2/targets/x86_64-linux/include/cuda_gl_interop.h
[INFO]: Installed: /usr/local/cuda-10.2/targets/x86_64-linux/include/sm_20_atomic_functions.hpp
[INFO]: Skipping copy. File already exists at: /usr/local/cuda-10.2/targets/x86_64-linux/include/cufft.h
[INFO]: Skipping copy. File already exists at: /usr/local/cuda-10.2/targets/x86_64-linux/include/cuda_fp16.hpp
[INFO]: Skipping copy. File already exists at: /usr/local/cuda-10.2/targets/x86_64-linux/include/host_defines.h
Finally a cleanup that accually removes everything except some hidden folder @ /var/log/nvidia/.uninstallManifests
[INFO]: md5 matches, removing file /var/log/nvidia/.uninstallManifests/
[ERROR]: boost::filesystem::remove: Directory not empty: "/var/log/nvidia/.uninstallManifests/"
[INFO]: Removing symlink: /usr/local/cuda
What did I execute?
sudo ./cuda_10.2.89_440.33.01_linux.run --override
- accepted EULA
- disabled driver, samples, demo and documentation
Driver Version 440.82 in use with an GTX 1080Ti:
╰─$ nvidia-smi
Tue Jun 2 21:55:55 2020
| NVIDIA-SMI 440.82 Driver Version: 440.82 CUDA Version: 10.2 |
| 0 GeForce GTX 108... Off | 00000000:09:00.0 On | N/A |
| 0% 60C P0 66W / 250W | 721MiB / 11175MiB | 0% Default |
