CUDA 10.1 segmentationTree.cu error
Severity Code Description Project File Line Suppression State
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\bin\nvcc.exe” -gencode=arch=compute_30,code="sm_30,compute_30" -gencode=arch=compute_35,code="sm_35,compute_35" -gencode=arch=compute_37,code="sm_37,compute_37" -gencode=arch=compute_50,code="sm_50,compute_50" -gencode=arch=compute_52,code="sm_52,compute_52" -gencode=arch=compute_60,code="sm_60,compute_60" -gencode=arch=compute_61,code="sm_61,compute_61" -gencode=arch=compute_70,code="sm_70,compute_70" -gencode=arch=compute_75,code="sm_75,compute_75" --use-local-env -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\bin\HostX86\x64” -x cu -I./ -I…/…/common/inc -I./ -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include” -I…/…/common/inc -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler “/wd 4819” -g -DWIN32 -DWIN32 -D_MBCS -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Fdx64/Debug/vc141.pdb /FS /Zi /RTC1 /MTd " -o x64/Debug/segmentationTree.cu.obj “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.1\6_Advanced\segmentationTreeThrust\segmentationTree.cu”” exited with code 2. segmentationTreeThrust C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\IDE\VC\VCTargets\BuildCustomizations\CUDA 10.1.targets 757
While running the detailed error, I got this and can’t get why the samples are not building up.
1>------ Up-To-Date check: Project: segmentationTreeThrust, Configuration: Debug x64 ------
1>Project is not up-to-date: last build was unsuccessful.
1>------ Build started: Project: segmentationTreeThrust, Configuration: Debug x64 ------
1>Build started 3/11/2019 10:24:10 PM.
1>Building with tools version “15.0”.
1>Project file contains ToolsVersion=“4.0”. This toolset may be unknown or missing, in which case you may be able to resolve this by installing the appropriate version of MSBuild, or the build may have been forced to a particular ToolsVersion for policy reasons. Treating the project as if it had ToolsVersion=“15.0”. For more information, please see MSBuild Toolset (ToolsVersion) - MSBuild | Microsoft Docs.
1>Target “EnableIntermediateOutputPathMismatchWarning” skipped, due to false condition; (‘$(RestoreProjectStyle)’ == ‘PackageReference’) was evaluated as (‘’ == ‘PackageReference’).
1>Target _CheckForInvalidConfigurationAndPlatform:
1> Task “Error” skipped, due to false condition; ( ‘$(_InvalidConfigurationError)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1> Task “Warning” skipped, due to false condition; ( ‘$(_InvalidConfigurationWarning)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1> Using “Message” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “Message”
1> Configuration=Debug
1> Done executing task “Message”.
1> Task “Message”
1> Platform=x64
1> Task “Error” skipped, due to false condition; (‘$(OutDir)’ != ‘’ and !HasTrailingSlash(‘$(OutDir)’)) was evaluated as (‘…/…/bin/win64/Debug/’ != ‘’ and !HasTrailingSlash(‘…/…/bin/win64/Debug/’)).
1> Task “Error” skipped, due to false condition; (‘$(BaseIntermediateOutputPath)’ != ‘’ and !HasTrailingSlash(‘$(BaseIntermediateOutputPath)’)) was evaluated as (‘obj' != ‘’ and !HasTrailingSlash(‘obj')).
1> Task “Error” skipped, due to false condition; (’$(IntermediateOutputPath)’ != ‘’ and !HasTrailingSlash(‘$(IntermediateOutputPath)’)) was evaluated as (‘x64/Debug/’ != ‘’ and !HasTrailingSlash(‘x64/Debug/’)).
1> Task “Error” skipped, due to false condition; ( ‘$(_InitialMSBuildProjectExtensionsPath)’ != ‘’ And ‘$(MSBuildProjectExtensionsPath)’ != ‘$(_InitialMSBuildProjectExtensionsPath)’ ) was evaluated as ( ‘C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.1\6_Advanced\segmentationTreeThrust\obj' != ‘’ And ‘C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.1\6_Advanced\segmentationTreeThrust\obj' != ‘C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.1\6_Advanced\segmentationTreeThrust\obj' ).
1> Task “Warning” skipped, due to false condition; ( ‘$(EnableBaseIntermediateOutputPathMismatchWarning)’ == ‘true’ And ‘$(_InitialBaseIntermediateOutputPath)’ != ‘$(BaseIntermediateOutputPath)’ And ‘$(BaseIntermediateOutputPath)’ != ‘$(MSBuildProjectExtensionsPath)’ ) was evaluated as ( ‘’ == ‘true’ And ‘obj' != ‘obj' And ‘obj' != ‘C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.1\6_Advanced\segmentationTreeThrust\obj' ).
1>Target “_CheckForInvalidConfigurationAndPlatform” skipped. Previously built successfully.
1>Target SetTelemetryEnvironmentVariables:
1> Using “SetEnv” task from assembly “C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\IDE\VC\VCTargets\Microsoft.Build.CppTasks.Common.dll”.
1> Task “SetEnv”
1> VSTEL_SolutionSessionID={E3254332-655D-4A14-86BE-773EBE039631}
1> Done executing task “SetEnv”.
1> Task “SetEnv”
1> VSTEL_CurrentSolutionBuildID=300540687
1> Task “SetEnv”
1> VSTEL_ProjectID={ABADF80F-BE62-4563-9B92-9DB8C003D855}
1>Target _PrepareForBuild:
1> Task “CreateItem” skipped, due to false condition; (’%(CustomBuild.IncludeFileToTool)’!=’’) was evaluated as (’’!=’‘).
1>Target _PrepareForReferenceResolution:
1> Task “Message” skipped, due to false condition; (’$(_REFERENCE_DEBUG)‘==‘true’) was evaluated as (’‘==‘true’).
1>Target “ComputeCrtSDKReference” skipped, due to false condition; (’@(ClCompile)‘!=’’ and ‘$(WindowsAppContainer)’==‘true’ and ‘$(UseCrtSDKReference)’ != ‘false’) was evaluated as (‘’!=‘’ and ‘false’==‘true’ and ‘’ != ‘false’).
1>Target BeforeResolveReferences:
1>Target AssignProjectConfiguration:
1> Using “AssignProjectConfiguration” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “AssignProjectConfiguration”
1> Done executing task “AssignProjectConfiguration”.
1>Target “AssignProjectConfiguration” skipped. Previously built successfully.
1>Target _SplitProjectReferencesByFileExistence:
1> Task “ResolveNonMSBuildProjectOutput” skipped, due to false condition; (‘$(BuildingInsideVisualStudio)’==‘true’ and ‘@(ProjectReferenceWithConfiguration)’!=‘’) was evaluated as (‘true’==‘true’ and ‘’!=‘’).
1>Target _GetProjectReferenceTargetFrameworkProperties:
1> Using “MSBuild” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “MSBuild”
1> Done executing task “MSBuild”.
1> Task “GetReferenceNearestTargetFrameworkTask” skipped, due to false condition; (‘@(_ProjectReferenceTargetFrameworkPossibilities->Count())’ != ‘0’ and ‘$(ReferringTargetFrameworkForProjectReferences)’ != ‘’) was evaluated as (‘0’ != ‘0’ and ‘.NETFramework,Version=v4.0’ != ‘’).
1>Target PrepareProjectReferences:
1>Target “_RemoveNameMetadataFromProjectReferenceItems” skipped, due to false condition; (‘@(ProjectReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Target ResolveProjectReferences:
1> Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and (‘$(BuildingInsideVisualStudio)’ == ‘true’ or ‘$(BuildProjectReferences)’ != ‘true’) and ‘$(VisualStudioVersion)’ != ‘10.0’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and (‘true’ == ‘true’ or ‘true’ != ‘true’) and ‘15.0’ != ‘10.0’ and ‘’ != ‘’).
1> Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and (‘$(BuildingInsideVisualStudio)’ == ‘true’ or ‘$(BuildProjectReferences)’ != ‘true’) and ‘$(VisualStudioVersion)’ == ‘10.0’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and (‘true’ == ‘true’ or ‘true’ != ‘true’) and ‘15.0’ == ‘10.0’ and ‘’ != ‘’).
1> Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘$(BuildingInsideVisualStudio)’ != ‘true’ and ‘$(BuildProjectReferences)’ == ‘true’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and ‘true’ != ‘true’ and ‘true’ == ‘true’ and ‘’ != ‘’).
1> Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘$(BuildingProject)’ == ‘true’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and ‘true’ == ‘true’ and ‘’ != ‘’).
1> Task “Warning” skipped, due to false condition; (‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘@(_MSBuildProjectReferenceNonexistent)’ != ‘’) was evaluated as (‘’ != ‘’ and ‘’ != ‘’).
1>Target “FindInvalidProjectReferences” skipped, due to false condition; (‘$(FindInvalidProjectReferences)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1>Target “ResolveNativeReferences” skipped, due to false condition; (‘@(NativeReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Target “_PrepareForReferenceResolution” skipped. Previously built successfully.
1>Target “ResolveProjectReferences” skipped. Previously built successfully.
1>Target GetFrameworkPaths:
1>Target “GetWinFXPath” skipped, due to false condition; ((‘@(Page)’ != ‘’ or ‘@(ApplicationDefinition)’ != ‘’ or ‘@(Resource)’ != ‘’) and (‘$(GetWinFXNativePath)’ != ‘’ or ‘$(GetWinFXWoWPath)’ != ‘’ )) was evaluated as ((‘’ != ‘’ or ‘’ != ‘’ or ‘’ != ‘’) and (‘’ != ‘’ or ‘’ != ‘’ )).
1>Target “GetFrameworkPaths” skipped. Previously built successfully.
1>Target GetReferenceAssemblyPaths:
1> Task “GetReferenceAssemblyPaths” skipped, due to false condition; (‘$(TargetFrameworkMoniker)’ != ‘’ and (‘$(_TargetFrameworkDirectories)’ == ‘’ or ‘$(_FullFrameworkReferenceAssemblyPaths)’ == ‘’)) was evaluated as (‘’ != ‘’ and (‘C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.0’ == ‘’ or ‘C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.0’ == ‘’)).
1>Target SetBuildDefaultEnvironmentVariables:
1> Task “SetEnv”
1> PATH=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\bin\HostX86\x64;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\bin\HostX86\x86;C:\Program Files (x86)\Windows Kits\10\bin\10.0.15063.0\x86;;C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.6.1 Tools;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\tools;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\ide;C:\Program Files (x86)\HTML Help Workshop;;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\MSBuild\15.0\Bin;C:\Windows\Microsoft.NET\Framework\v4.0.30319;;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\libnvvp;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\libnvvp;C:\VulkanSDK\1.1.97.0\Bin;C:\Program Files\Microsoft MPI\Bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Program Files\dotnet;C:\Program Files\Microsoft SQL Server\130\Tools\Binn;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files\NVIDIA Corporation\Nsight Compute 2019.1;C:\Users\gpaak\AppData\Local\Programs\Python\Python37-32\Scripts;C:\Users\gpaak\AppData\Local\Programs\Python\Python37-32;C:\Users\gpaak\AppData\Local\Microsoft\WindowsApps;;C:\Users\gpaak\AppData\Local\Programs\Microsoft VS Code\bin;
1> Task “SetEnv”
1> LIB=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\lib\x64;;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\atlmfc\lib\x64;;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Auxiliary\VS\lib\x64;;C:\Program Files (x86)\Windows Kits\10\lib\10.0.15063.0\ucrt\x64;;;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Auxiliary\VS\UnitTest\lib;C:\Program Files (x86)\Windows Kits\10\lib\10.0.15063.0\um\x64;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\lib\um\x64;;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Lib\um\x64
1> Task “SetEnv”
1> LIBPATH=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\atlmfc\lib\x64;;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\lib\x64;
1> Task “SetEnv”
1> INCLUDE=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include;;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\atlmfc\include;;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Auxiliary\VS\include;;C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\ucrt;;;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Auxiliary\VS\UnitTest\include;C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um;C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\shared;C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\winrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Include\um;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Include\um;
1>Target “SetUserMacroEnvironmentVariables” skipped, due to false condition; (‘@(BuildMacro)’ != ‘’ and ‘$(DesignTimeBuild)’ != ‘true’) was evaluated as (‘’ != ‘’ and ‘’ != ‘true’).
1>Target GetResolvedWinMD:
1>Target PlatformPrepareForBuild:
1> Task “VCMessage” skipped, due to false condition; (‘$(_Error64bitToolsNotInstalled)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(_ToolsetFound)’ != ‘true’ and ‘$(PlatformToolset)’ == ‘’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v141’ == ‘’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(_ToolsetFound)’ != ‘true’ and ‘$(PlatformToolset)’ == ‘v110’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v141’ == ‘v110’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(_ToolsetFound)’ != ‘true’ and ‘$(PlatformToolset)’ == ‘v100’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v141’ == ‘v100’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(_ToolsetFound)’ != ‘true’ and ‘$(PlatformToolset)’ == ‘v90’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v141’ == ‘v90’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(_ToolsetFound)’ != ‘true’ and ‘$(PlatformToolset)’ != ‘v90’ and ‘$(PlatformToolset)’ != ‘v100’ and ‘$(PlatformToolset)’ != ‘v110’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v141’ != ‘v90’ and ‘v141’ != ‘v100’ and ‘v141’ != ‘v110’).
1>Target _CheckWindowsSDKInstalled:
1> Task “VCMessage” skipped, due to false condition; (‘$(WindowsSDKInstalled)’ != ‘true’) was evaluated as (‘true’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(WindowsAppContainer)’ != ‘true’ and ‘$(WindowsSDK_Desktop_Support)’ != true) was evaluated as (‘false’ != ‘true’ and ‘true’ != true).
1>Target “GetReferenceAssemblyPaths” skipped. Previously built successfully.
1>Target “AssignLinkMetadata” skipped, due to false condition; ( ‘$(SynthesizeLinkMetadata)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1>Target SetCABuildNativeEnvironmentVariables:
1> Task “SetEnv”
1> CAExcludePath=C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\atlmfc\include;C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include;C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\ucrt;;C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um;C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\shared;C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\winrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Include\um;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\Include\um;
1>Target PrepareForBuild:
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’ != ‘true’ and ‘$(ConfigurationPlatformExists)’ != ‘true’) was evaluated as (‘’ != ‘true’ and ‘true’ != ‘true’).
1> Using “MakeDir” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “MakeDir”
1> Done executing task “MakeDir”.
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(WindowsAppContainer)’==‘true’ and ‘$(ConfigurationType)’!=‘Application’ and ‘$(ConfigurationType)’!=‘DynamicLibrary’ and ‘$(ConfigurationType)’!=‘StaticLibrary’) was evaluated as (‘’!=‘true’ and ‘false’==‘true’ and ‘Application’!=‘Application’ and ‘Application’!=‘DynamicLibrary’ and ‘Application’!=‘StaticLibrary’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCToolsInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’ and (‘$(TargetFrameworkVersion)’==‘v3.5’ or ‘$(TargetFrameworkVersion)’==‘v3.0’ or ‘$(TargetFrameworkVersion)’==‘v2.0’ )) was evaluated as (‘’!=‘true’ and ‘C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023'==’’ and ‘’ != ‘true’ and (‘v4.0’==‘v3.5’ or ‘v4.0’==‘v3.0’ or ‘v4.0’==‘v2.0’ )).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCToolsInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’ and ‘$(PlatformToolset)’==‘v90’) was evaluated as (‘’!=‘true’ and ‘C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023'==’’ and ‘’ != ‘true’ and ‘v141’==‘v90’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCToolsInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’) was evaluated as (‘’!=‘true’ and ‘C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023'==’’ and ‘’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(WindowsSDKDir)’==‘’ and ‘$(UseEnv)’ != ‘true’) was evaluated as (‘’!=‘true’ and ‘C:\Program Files (x86)\Windows Kits\10'==’’ and ‘’ != ‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(IntDirTrailingSlashWarning)’==‘true’) was evaluated as (‘’!=‘true’ and ‘’==‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(OutDirTrailingSlashWarning)’==‘true’) was evaluated as (‘’!=‘true’ and ‘’==‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘%(CompatibilityIssues.Identity)’ != ‘’ and ‘$(DesignTimeBuild)’!=‘true’) was evaluated as (‘’ != ‘’ and ‘’!=‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(IgnoreWarnIntDirSharingDetected)’ != ‘true’ and ‘$(IntDirSharingDetected)’ == ‘true’) was evaluated as (‘’ != ‘true’ and ‘’ == ‘true’).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(IgnoreWarnIntDirInTempDetected)’ != ‘true’ and (‘$(_IntDirFullpath.StartsWith($(Tmp), true, null))’ == ‘true’ or ‘$(_IntDirFullpath.StartsWith($(Temp), true, null))’ == ‘true’ or ‘$(_OutDirFullpath.StartsWith($(Tmp), true, null))’ == ‘true’ or ‘$(_OutDirFullpath.StartsWith($(Temp), true, null))’ == ‘true’)) was evaluated as (‘’!=‘true’ and ‘’ != ‘true’ and (‘False’ == ‘true’ or ‘False’ == ‘true’ or ‘False’ == ‘true’ or ‘False’ == ‘true’)).
1> Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’ != ‘true’ and ‘$(SpectreMitigation)’ != ‘’ and ‘$(SpectreMitigation)’ != ‘false’ and ((‘$(_VC_Target_Library_Platform)’ == ‘OneCore’ and !Exists(‘$(VC_LibraryPath_VC_x86_OneCore)’)) or (‘$(_VC_Target_Library_Platform)’ == ‘Desktop’ and !Exists(‘$(VC_LibraryPath_VC_x86_Desktop)’)))) was evaluated as (‘’ != ‘true’ and ‘false’ != ‘’ and ‘false’ != ‘false’ and ((‘Desktop’ == ‘OneCore’ and !Exists(‘C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\lib\onecore\x86’)) or (‘Desktop’ == ‘Desktop’ and !Exists(‘C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\lib\x86’)))).
1> Task “MakeDir”
1>Target “ComputeCrtSDKReference” skipped, due to false condition; (‘@(ClCompile)’!=‘’ and ‘$(WindowsAppContainer)’==‘true’ and ‘$(UseCrtSDKReference)’ != ‘false’) was evaluated as (‘’!=‘’ and ‘false’==‘true’ and ‘’ != ‘false’).
1>Target “GetInstalledSDKLocations” skipped, due to false condition; (‘@(SDKReference)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target ResolveSDKReferences:
1> Task “ResolveSDKReference” skipped, due to false condition; (‘@(SDKReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Target “ResolveSDKReferences” skipped. Previously built successfully.
1>Target ExpandSDKReferences:
1> Task “GetSDKReferenceFiles” skipped, due to false condition; (‘@(ResolvedSDKReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Target “ResolveNuGetPackageAssets” skipped, due to false condition; (‘$(ResolveNuGetPackages)’ == ‘true’ and exists(‘$(ProjectLockFile)’)) was evaluated as (‘true’ == ‘true’ and exists(‘obj\project.assets.json’)).
1>Target “ImplicitlyExpandNETStandardFacades” skipped, due to false condition; (‘$(ImplicitlyExpandNETStandardFacades)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1>Target _HandlePackageFileConflicts:
1> Using “ResolvePackageFileConflicts” task from assembly “C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\MSBuild\Microsoft\Microsoft.NET.Build.Extensions\tools\net46\Microsoft.NET.Build.Extensions.Tasks.dll”.
1> Task “ResolvePackageFileConflicts”
1> Done executing task “ResolvePackageFileConflicts”.
1>Target ResolveAssemblyReferences:
1> Task “ResolveAssemblyReference” skipped, due to false condition; (‘@(Reference)’!=‘’ or ‘@(_ResolvedProjectReferencePaths)’!=‘’ or ‘@(_ExplicitReference)’ != ‘’) was evaluated as (‘’!=‘’ or ‘’!=‘’ or ‘’ != ‘’).
1>Target “GenerateBindingRedirects” skipped, due to false condition; (‘$(AutoGenerateBindingRedirects)’ == ‘true’ and ‘$(GenerateBindingRedirectsOutputType)’ == ‘true’) was evaluated as (‘’ == ‘true’ and ‘true’ == ‘true’).
1>Target “_RemoveZipFileSuggestedRedirect” skipped, due to false condition; (‘$(_TargetFrameworkVersionWithoutV)’ >= ‘4.7.1’ And ‘$(AllowZipFileRedirect)’ != ‘true’) was evaluated as (‘4.0’ >= ‘4.7.1’ And ‘’ != ‘true’).
1>Target “GenerateBindingRedirectsUpdateAppConfig” skipped, due to false condition; (‘$(AutoGenerateBindingRedirects)’ == ‘true’ and ‘$(GenerateBindingRedirectsOutputType)’ == ‘true’ and Exists(‘$(_GenerateBindingRedirectsIntermediateAppConfig)’)) was evaluated as (‘’ == ‘true’ and ‘true’ == ‘true’ and Exists(‘x64/Debug/segmentationTreeThrust.exe.config’)).
1>Target “ResolveComReferences” skipped, due to false condition; (‘@(COMReference)’!=‘’ or ‘@(COMFileReference)’!=‘’) was evaluated as (‘’!=‘’ or ‘’!=‘’).
1>Target AfterResolveReferences:
1>Target “ImplicitlyExpandDesignTimeFacades” skipped, due to false condition; (‘$(ImplicitlyExpandDesignTimeFacades)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1>Target “ResolveTestReferences” skipped, due to false condition; (‘@(Shadow)’!=‘’) was evaluated as (‘’!=‘’).
1>Target ResolveReferences:
1>Target “PrepareForBuild” skipped. Previously built successfully.
1>Target InitializeBuildStatus:
1> Using “ReadLinesFromFile” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “ReadLinesFromFile”
1> Done executing task “ReadLinesFromFile”.
1> Using “WriteLinesToFile” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “WriteLinesToFile”
1> Done executing task “WriteLinesToFile”.
1> Using “Touch” task from assembly “Microsoft.Build.Tasks.Core, Version=15.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1> Task “Touch”
1> Touching “x64/Debug/segmenta.ABADF80F.tlog\unsuccessfulbuild”.
1> Done executing task “Touch”.
1>Target “PrepareProjectReferences” skipped. Previously built successfully.
1>Target BuildGenerateSourcesTraverse:
1> Task “MSBuild” skipped, due to false condition; (‘$(BuildPassReferences)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’ and ‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and ‘’ != ‘’ and ‘’ == ‘true’).
1>Target “ResolveReferences” skipped. Previously built successfully.
1>Target BeforeBuildGenerateSources:
1>Target PreBuildEvent:
1> Task “Message” skipped, due to false condition; (‘%(PreBuildEvent.Message)’ != ‘’ and ‘%(PreBuildEvent.Command)’ != ‘’) was evaluated as (‘’ != ‘’ and ‘’ != ‘’).
1> Task “Exec” skipped, due to false condition; (‘%(PreBuildEvent.Command)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target “CustomBuild” skipped, due to false condition; (‘@(CustomBuild)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target “FxExport” skipped, due to false condition; (‘@(FxCompile)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target “FxCompile” skipped, due to false condition; (‘@(FxCompile)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target “InitializeBuildStatus” skipped. Previously built successfully.
1>Target “SetBuildDefaultEnvironmentVariables” skipped. Previously built successfully.
1>Target _SelectedFiles:
1>Target “CudaFilterSelectedFiles” skipped, due to false condition; (‘@(SelectedFiles)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target InitializeCudaHostProperties:
1>Target AddCudaCompileMetadata:
1> Building target “AddCudaCompileMetadata” completely.
1> No input files were specified.
1> Using “SanitizePaths” task from assembly “C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\IDE\VC\VCTargets\BuildCustomizations\Nvda.Build.CudaTasks.v10.1.dll”.
1> Task “SanitizePaths”
1> Done executing task “SanitizePaths”.
1> Using “SplitToItemMetadata” task from assembly “C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\IDE\VC\VCTargets\BuildCustomizations\Nvda.Build.CudaTasks.v10.1.dll”.
1> Task “SplitToItemMetadata”
1> Done executing task “SplitToItemMetadata”.
1>Target “AddCudaCompileMetadata” skipped. Previously built successfully.
1>Target “InitializeCudaHostProperties” skipped. Previously built successfully.
1>Target InitializeCudaProjectProperties:
1>Target AddCudaLinkMetadata:
1> Building target “AddCudaLinkMetadata” completely.
1> Using “ResolvePaths” task from assembly “C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\IDE\VC\VCTargets\BuildCustomizations\Nvda.Build.CudaTasks.v10.1.dll”.
1> Task “ResolvePaths”
1> Done executing task “ResolvePaths”.
1>Target AddCudaCompileDeps:
1> Skipping target “AddCudaCompileDeps” because all output files are up-to-date with respect to the input files.
1> Input files: segmentationTree.cu;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\cuda_runtime.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\crt/host_config.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\vcruntime.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\sal.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\concurrencysal.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\vadefs.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\vector_types.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\limits.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\stddef.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\library_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\channel_descriptor.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\cuda_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\cuda_device_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\driver_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\vector_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\vector_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\crt/common_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\crt\host_defines.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\string.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_memory.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_memcpy_s.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\errno.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\vcruntime_string.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_wstring.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\time.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_wtime.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\crt\math_functions.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\math.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_math.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\stdlib.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_malloc.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_search.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_wstdlib.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\cmath;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\yvals.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\yvals_core.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xkeycheck.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\crtdbg.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\vcruntime_new_debug.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\vcruntime_new.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\use_ansi.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\cstdlib;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xtgmath.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xtr1common;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\crt\math_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\cuda_surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\cuda_texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\crt/device_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\crt\device_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\device_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\crt\device_double_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\crt\device_double_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\sm_20_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\sm_32_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\sm_35_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\sm_60_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\sm_20_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\sm_30_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\sm_32_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\sm_35_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\sm_61_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\crt\sm_70_rt.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\surface_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\texture_fetch_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\texture_indirect_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\surface_indirect_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\device_launch_parameters.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\stdio.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_wstdio.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_stdio_config.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\iostream;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\istream;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\ostream;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\ios;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xlocnum;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\climits;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\cstdio;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\streambuf;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xiosbase;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xlocale;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\cstring;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\stdexcept;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\exception;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\type_traits;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xstddef;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\cstddef;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\initializer_list;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\malloc.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\vcruntime_exception.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\eh.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_terminate.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xstring;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xmemory0;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\cstdint;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\stdint.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\limits;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\ymath.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\cfloat;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\float.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\cwchar;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\wchar.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_wconio.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_wctype.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_wdirect.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_wio.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_share.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\corecrt_wprocess.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\sys/stat.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\sys/types.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\new;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xutility;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\utility;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\iosfwd;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xatomic0.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\intrin0.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\typeinfo;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\vcruntime_typeinfo.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xlocinfo;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xlocinfo.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\ctype.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\locale.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\memory;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xmemory;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xfacet;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\system_error;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\cerrno;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xcall_once.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xerrc.h;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\share.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\fstream;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\iterator;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\vector;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\list;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\deque;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\algorithm;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/discard_iterator.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/version.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config/config.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config/simple_defines.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config/compiler.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config/cpp_dialect.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config/cpp_compatibility.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config/host_system.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config/device_system.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config/host_device.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config/debug.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config/forceinline.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config/exec_check_disable.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/config/global_workarounds.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/discard_iterator_base.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/counting_iterator.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/iterator_adaptor.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/iterator_facade.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/type_traits.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/type_traits/has_trivial_assign.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/iterator_facade_category.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/host_system_tag.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cpp/detail/execution_policy.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/sequential/execution_policy.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/execution_policy.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/device_system_tag.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/execution_policy.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/any_system_tag.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/config.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/allocator_aware_execution_policy.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/execute_with_allocator_fwd.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/alignment.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/iterator_categories.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/iterator_category_with_system_and_traversal.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/iterator_traversal_tags.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/universal_categories.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/is_iterator_category.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/iterator_category_to_traversal.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/iterator_category_to_system.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/distance_from_result.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/use_default.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/iterator_adaptor_base.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/iterator_traits.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/type_traits/void_t.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/iterator_traits.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/counting_iterator.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/numeric_traits.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/any_assign.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/transform_iterator.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/transform_iterator.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/type_traits/result_of_adaptable_function.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/type_traits/function_traits.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/type_traits/has_nested_type.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/zip_iterator.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/zip_iterator_base.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/minimum_category.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/type_traits/minimum_type.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/minimum_system.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/type_traits/is_metafunction_defined.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/tuple.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/tuple.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/swap.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/pair.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/pair.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/tuple_meta_transform.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/tuple_transform.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/tuple_of_iterator_references.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/reference_forward_declaration.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/iterator/detail/zip_iterator.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/for_each.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/for_each.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/select_system.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/select_system.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/select_system_exists.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/for_each.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/tag.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/static_assert.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/preprocessor.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/adl/for_each.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/sequential/for_each.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/function.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/raw_reference_cast.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/raw_pointer_cast.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/type_traits/pointer_traits.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cpp/detail/for_each.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/for_each.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/util.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/cub/util_arch.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\util_namespace.cuh;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system_error.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/error_code.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/errno.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/error_category.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/functional.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\functional;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\tuple;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/placeholder.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/actor.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/value.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/composite.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/operators/assignment_operator.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/operators/operator_adaptors.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/actor.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/argument.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/operators.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/operators/arithmetic_operators.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/operators/relational_operators.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/operators/logical_operators.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/operators/bitwise_operators.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/functional/operators/compound_assignment_operators.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/error_code.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/error_condition.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/system_error.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\string;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\xstring_insert.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/system_error.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/error.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/guarded_driver_types.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\driver_types.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/error.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/guarded_cuda_runtime_api.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\cuda_runtime_api.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/parallel_for.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/par_to_seq.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/seq.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/par.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/core/agent_launcher.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/core/triple_chevron_launch.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/core/alignment.h;C:\Program Files %28x86%29\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\include\cassert;C:\Program Files %28x86%29\Windows Kits\10\Include\10.0.15063.0\ucrt\assert.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/core/util.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\cuda_occupancy.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/type_traits/is_contiguous_iterator.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/cub/block/block_load.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\block\block_exchange.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\block../util_ptx.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\util_type.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\util_macro.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\util_debug.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\block../iterator/cache_modified_input_iterator.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\iterator../thread/thread_load.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\iterator../thread/thread_store.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\iterator../util_device.cuh;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/cub/block/block_store.cuh;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/cub/block/block_scan.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\block\specializations/block_scan_raking.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\block\specializations../…/block/block_raking_layout.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\block\specializations../…/thread/thread_reduce.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\thread../thread/thread_operators.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\block\specializations../…/thread/thread_scan.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\block\specializations../…/warp/warp_scan.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\warp\specializations/warp_scan_shfl.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\warp\specializations/warp_scan_smem.cuh;c:\program files\nvidia gpu computing toolkit\cuda\v10.1\include\thrust\system\cuda\detail\cub\block\specializations/block_scan_warp_scans.cuh;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/distance.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/distance.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/advance.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/advance.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/advance.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/advance.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/distance.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/distance.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/reduce.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/reduce.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/reduce.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/reduce.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/reduce_by_key.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/reduce_by_key.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/type_traits/iterator/is_output_iterator.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/transform.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/transform.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/transform.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/generic/transform.inl;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/detail/internal_functional.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/adl/transform.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/detail/sequential/transform.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cpp/detail/transform.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include\thrust/system/cuda/detail/transform.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA
