Impossible to install cuda 10 from 0 and optix in linux, it may be a problem of compatibility between cards ?.
I also have the problem compiling everything cuda toolkit with “runfile (local)”. This installs the driver 418.xx but I no longer recognize the rtx if the gtx.
I get it every time I want to install cuda 10.
dpkg: error processing archive /var/cache/apt/archives/libcublas-dev_10.1.0.105-1_amd64.deb (–unpack):
trying to overwrite ‘/usr/include/cublas_v2.h’, which is also in package nvidia-cuda-dev 9.1.85-3ubuntu1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process / usr / bin / dpkg returned an error code (1)
Ubuntu 18.10
Ryzen 1700
evga 970sc.
Evga 2070super.
