I launched the cuda local installer (cuda_10.0.130_411.31_win10.exe) on my brand new surface book 2 (windows 10 pro 1803 17134.407).
The installation apparently was ok. From Visual Studio with the cuda plugin I can compile the sample programs, but when I try to run them, I get an error message stating that there is no GPU available.
I tried the suggestion from your link, both setting “High performance NVIDIA processor” for the sample executable and then as a global setting, but I keep getting “Error: only 0 devices available, 1 requested. Exiting.”
I also use CUDA 10 on a Surface Book 2 and had problems with the driver that the CUDA 10 installer uses. After the driver installs I noticed that the 1060 is shown in Device Manager as being in an error state due to the drivers not being signed.
The quickest solution is to just download the latest 1060 Notebook drivers from NVIDIA.com rather than relying on the ones that shipped with the CUDA SDK. After I installed the latest 417.01 drivers and replaced the unsigned ones everything was fine.
In the bext days, as soon as I find a slice of time, I am going to try your suggestion – install cuda 10 without driver, then update the driver only, and I’ll report here the result.
By the way – after installation of the latest drivers from nvidia.com, are you still able to detach the screen of the surface book?
