Hi everyone
I currently try to compile a CUDA code in MSVS 2022 (Version 17.12.3) using CUDA Toolkit 12.6. Originally, the code was written using MSVS 2019 and CUDA Toolkit 10.1.
I now encounter the error that build errors are found in the limits files. See log below:
Column 1 | Column 2 | Column 3 | Column 4 | E | F | G | H |
Severity | Code | Description | Project | File | Line | Suppression State | Details |
Error | C2143 | syntax error: missing ‘)’ before ‘;’ | CudaRuntime3 | C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.6\include\cuda\std\detail\libcxx\include\limits | 218 | ||
Error | C2059 | syntax error: ‘)’ | CudaRuntime3 | C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.6\include\cuda\std\detail\libcxx\include\limits | 218 | ||
Error | C2238 | unexpected token(s) preceding ‘;’ | CudaRuntime3 | C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.6\include\cuda\std\detail\libcxx\include\limits | 218 | ||
Error | C1201 | unable to continue after syntax error in class template definition | CudaRuntime3 | C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.6\include\cuda\std\detail\libcxx\include\limits | 218 | ||
Error | C2059 | syntax error: ‘)’ | CudaRuntime3 | C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.6\include\cuda\std\detail\libcxx\include\limits | 155 | ||
Error | C2334 | unexpected token(s) preceding ‘:’; skipping apparent function body | CudaRuntime3 | C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.6\include\cuda\std\detail\libcxx\include\limits | 155 | ||
CUDA toolkit is installed (I can compile the standard kernel.cu code). Since the code is not intended for public disclosure I cannot show it to you. However, maybe someone has encountered similar issues and know the cause/solution for this problem.
Thank you and cheers
