Hi, I’ve gotten the CUDA 2.0 SDK examples compiled, but the majority of them give “TEST FAILED” errors and such when run. I’m running RHEL4.7 (2.6.9-78.0.8.ELsmp) using both the 177.73 and 177.82 drivers (I have 2 systems to test with, both give the same errors) and the GeForce GTX 280.
Some examples of the output are:
[storm0 release]$ ./alignedTypes
Using device 0: GeForce GTX 280
Allocating memory...
Generating host input data array...
Uploading input data to GPU memory...
Testing misaligned types...
uint8...
Avg. time: 283.634583 ms / Copy throughput: 0.164176 GB/s.
TEST FAILED
uint16...
Avg. time: 282.249329 ms / Copy throughput: 0.164982 GB/s.
TEST FAILED
RGBA8_misaligned...
Avg. time: 281.692932 ms / Copy throughput: 0.165308 GB/s.
TEST FAILED
LA32_misaligned...
Avg. time: 282.705109 ms / Copy throughput: 0.164716 GB/s.
TEST FAILED
RGB32_misaligned...
Avg. time: 282.121643 ms / Copy throughput: 0.165057 GB/s.
TEST FAILED
RGBA32_misaligned...
Avg. time: 282.891663 ms / Copy throughput: 0.164608 GB/s.
TEST FAILED
Testing aligned types...
RGBA8...
Avg. time: 283.331879 ms / Copy throughput: 0.164352 GB/s.
TEST FAILED
I32...
Avg. time: 282.897919 ms / Copy throughput: 0.164604 GB/s.
TEST FAILED
LA32...
Avg. time: 282.514648 ms / Copy throughput: 0.164827 GB/s.
TEST FAILED
RGB32...
Avg. time: 283.734222 ms / Copy throughput: 0.164119 GB/s.
TEST FAILED
RGBA32...
^C
[storm0 release]$ ./simpleCUFFT
cufft: ERROR: /root/cuda-stuff/sw/rel/gpgpu/toolkit/r2.0/cufft/src/config.cu, line 106
cufft: ERROR: CUFFT_INTERNAL_ERROR
cufft: ERROR: /root/cuda-stuff/sw/rel/gpgpu/toolkit/r2.0/cufft/src/cufft.cu, line 115
cufft: ERROR: CUFFT_INVALID_PLAN
Test FAILED
cufft: ERROR: /root/cuda-stuff/sw/rel/gpgpu/toolkit/r2.0/cufft/src/cufft.cu, line 94
[storm0 release]$ ./simpleCUBLAS
simpleCUBLAS test running..
!!!! CUBLAS initialization error
Some things manage to run, but the bandwidth test seems really low:
[storm0 release]$ ./deviceQuery
There is 1 device supporting CUDA
Device 0: "GeForce GTX 280"
Major revision number: 1
Minor revision number: 3
Total amount of global memory: 1073020928 bytes
Number of multiprocessors: 30
Number of cores: 240
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.35 GHz
Concurrent copy and execution: Yes
Test PASSED
[storm0 release]$ ./bandwidthTest
Running on......
device 0:GeForce GTX 280
Quick Mode
Host to Device Bandwidth for Pageable memory
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 111.2
Quick Mode
Device to Host Bandwidth for Pageable memory
33554432 116.9
Quick Mode
Device to Device Bandwidth
33554432 212.0
&&&& Test PASSED
I also get this in dmesg when the module loads:
NVRM: loading NVIDIA UNIX x86_64 Kernel Module 177.82 Tue Nov 4 16:50:05 PST 2008
NVRM: PAT configuration unsupported, falling back to MTRRs.
Now, I’ve read something online that suggests if the nvidia driver falls back to MTRR as opposed to using PAT, that it may break CUDA support. Does anyone know if this is true? Thanks.
