CUDA 2.1 on VS 2008 Queries regarding compiler settings
Hello All,
I have been following posts on CUDA setup on VS2005. I am using CUDA 2.1 on VS2008. I am this much sure that CUDA2.1 runs on VS2008 because I am successfully able to run NVIDIA’s SDK examples on my machine. My machine has Vista 32 and NVidia GeForce 8800S, that supports CUDA 2.1.(Driver version 181.2).
Problem is I wrote a simple function for matrix multiplication. Precisely I am referring to Ch 6 from Programming Guide , CUDA example.
As per the guide, I created two files , one containing device code and other for host.
But when I compile, it gives me following error:
1>Project : error PRJ0019: A tool returned an error code from “Compiling with CUDA Build Rule…”
and I am using following compiler settings:
1>“C:\CUDA\bin\nvcc.exe” -arch sm_10 -ccbin “C:\Program Files\Microsoft Visual Studio 9.0\VC\bin” -Xcompiler "/EHsc /W3 /nologo /O2 /Zi /MT " -maxrregcount=32 --compile -o Debug\Add.cu.obj Add.cu
I am not able to figure out what is going wrong.
My source code for device : Add.cu
#include <stdio.h>
#include <stdlib.h>
#include <cutil_inline.h>
// Device multiplication function called by Mul()
// Compute C = A * B
// wA is the width of A
// wB is the width of B
__global__ void Muld(float* A, float* B, int wA, int wB, float* C)
		// Block index
		int bx = blockIdx.x;
		int by = blockIdx.y;
		// Thread index
		int tx = threadIdx.x;
		int ty = threadIdx.y;
		// Index of the first sub-matrix of A processed by the block
		int aBegin = wA * BLOCK_SIZE * by;
		// Index of the last sub-matrix of A processed by the block
		int aEnd = aBegin + wA - 1;
		// Step size used to iterate through the sub-matrices of A
		int aStep = BLOCK_SIZE;
		// Index of the first sub-matrix of B processed by the block
		int bBegin = BLOCK_SIZE * bx;
		// Step size used to iterate through the sub-matrices of B
		int bStep = BLOCK_SIZE * wB;
		// The element of the block sub-matrix that is computed
		// by the thread
		float Csub = 0;
		// Loop over all the sub-matrices of A and B required to
		// compute the block sub-matrix
		for (int a = aBegin, b = bBegin;a <= aEnd; a += aStep, b += bStep)
			// Shared memory for the sub-matrix of A
			__shared__ float As[BLOCK_SIZE][BLOCK_SIZE];
			// Shared memory for the sub-matrix of B
			__shared__ float Bs[BLOCK_SIZE][BLOCK_SIZE];
			// Load the matrices from global memory to shared memory;
			// each thread loads one element of each matrix
			As[ty][tx] = A[a + wA * ty + tx];
			Bs[ty][tx] = B[b + wB * ty + tx];
			// Synchronize to make sure the matrices are loaded
			__syncthreads();
			// Multiply the two matrices together;
			// each thread computes one element
			// of the block sub-matrix
			for (int k = 0; k < BLOCK_SIZE; ++k)
			Csub += As[ty][k] * Bs[k][tx];
			// Synchronize to make sure that the preceding
			// computation is done before loading two new
			// sub-matrices of A and B in the next iteration
			__syncthreads();
		}//end for loop
		// Write the block sub-matrix to global memory;
		// each thread writes one element
		int c = wB * BLOCK_SIZE * by + BLOCK_SIZE * bx;
		C[c + wB * ty + tx] = Csub;
}//end of Muld() on GPU
and Host code, Source1.cpp
#include<windows.h>
//CUDA specific header files.
#include <cuda_runtime.h>
#include <cuda_gl_interop.h>
//extern "C" void* add(int* A, int* B, int* C, int N);
//Taking example from NVIDIA Programming Guide, Ch6.
// Thread block size
#define BLOCK_SIZE 16
// Forward declaration of the device multiplication function
__global__ void Muld(float*, float*, int, int, float*);
// Host multiplication function
// hA is the height of A
void Mul(const float* A, const float* B, int hA, int wA, int wB,float* C)
	int size;
	// Load A and B to the device
	float* Ad;
	size = hA * wA * sizeof(float);
	cudaMalloc((void**)&Ad, size);
	cudaMemcpy(Ad, A, size, cudaMemcpyHostToDevice);
	float* Bd;
	size = wA * wB * sizeof(float);
	cudaMalloc((void**)&Bd, size);
	cudaMemcpy(Bd, B, size, cudaMemcpyHostToDevice);
	// Allocate C on the device
	float* Cd;
	size = hA * wB * sizeof(float);
	cudaMalloc((void**)&Cd, size);
	// Compute the execution configuration assuming
	// the matrix dimensions are multiples of BLOCK_SIZE
	dim3 dimBlock(BLOCK_SIZE, BLOCK_SIZE);
	dim3 dimGrid(wB / dimBlock.x, hA / dimBlock.y);
	// Launch the device computation
	Muld<<<dimGrid, dimBlock>>>(Ad, Bd, wA, wB, Cd);
	// Read C from the device
	cudaMemcpy(C, Cd, size, cudaMemcpyDeviceToHost);
	// Free device memory
	cudaFree(Ad);
	cudaFree(Bd);
	cudaFree(Cd);
}//end of Mul() on the host.
//Main function.
void main(int argc , char* argv[])
  //Call Mul() that in turn calls Muld().
	float A[3][4] = { {2,3,4,8}, {1,3,5,1}, {2,8,7,5}};
	float B[3][4] = { {2,3,4,8}, {1,3,5,1}, {2,8,7,5}};
	float **C = NULL;
	C = (float**)malloc(sizeof(float*) * 3);
	for(int i = 0; i < 3; i++);
		C[i] = (float*)malloc(4 * sizeof(float));
		memset(C[i], 0, 4 * sizeof(float));
	//Call CPU version
	Mul(A,B,3,4,4,C);
		printf("C[%d] = %f", i, C[i]);
	//free memory from C
		free(C[i])
		C[i] = NULL;
}//end of main().
Kindly help on this. Thank you.
