cuda 3D array problem
Please help…
I want to add 3D array, i want to use for loop in global
global void add(int ***dev_a ,int ***dev_b,int ***dec_c)
for i=0;i<2;i++)
for j=0;j<2;j++)
for k=0;k<2;k++)
    dev_c[i][j][k]=dev_a[i][j][k]+dev_b[i][j][k];
How i can do this in cuda? please explain me with some code… thank you
Don’t use 3 dimensional arrays. All arrays are inherently 1d in memory, the 3d subscripts just store arrays of pointers to chunks of the 1d array. Use a 1d array and use pointer arithmetic to access it like a 3d array.
Example: dev_c[i][j][k] is the same as dev_c[k+NZ*(j+NY*i)]
Thank you for idea, its working for my cuda code. Thank you very much.
