CUDA 4.1 available
Congratulations! CUDA 4.1 seems to be the milestone that will make me upgrade from CUDA 2.3… finally External Image
Christian
a link
Visual profiler seems to have the same bug as the 4.1rc versions (The Official NVIDIA Forums | NVIDIA). Anyone has an idea how to fix it? Forgot to reinstall the driver; it works now!
Ha ha ha… Expect software/kernel failures – They fixed the “memory overruns” (accessing portions of memory that you should not) somewhere in the middle…So, if you r running into problems after upgrade, check your mem copies and overruns…
Hi Sarnath - where do you see this “memory overruns” fix???
thanks
eyal
