Hello, I’ve installed CUDA 5.0 on a new Debian 6.0. It works great, however I have a small issue, every single time I boot the OS, I have to run at least one cuda program as root so that my normal user can actually use it.
Any help on how to fix this?
I have that script on boot time, however it always fails, here’s the output I could find o dmesg:
[26167.688569] nvidia 0000:01:00.0: PCI INT A disabled
[26171.334627] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[26171.334634] nvidia 0000:01:00.0: setting latency timer to 64
[26171.334638] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=none,decodes=none:owns=io+mem
[26171.334730] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 304.54 Sat Sep 29 00:05:49 PDT 2012
[26190.712684] NVRM: Your system is not currently configured to drive a VGA console
[26190.712686] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver
[26190.712688] NVRM: requires the use of a text-mode VGA console. Use of other console
[26190.712690] NVRM: drivers including, but not limited to, vesafb, may result in
[26190.712691] NVRM: corruption and stability problems, and is not supported.
Seeing it now, I wonder if it can be something about the framebuffer?
I have this on the grub.conf:
menuentry 'Debian GNU/Linux, with Linux 2.6.32-5-amd64' --class debian --class gnu-linux --class gnu --class os {
set gfxpayload=1024x768
insmod part_msdos
insmod ext2
set root='(hd3,msdos1)'
search --no-floppy --fs-uuid --set cb634d3e-fd3b-4862-8ee6-1816cdbd2f1f
echo 'Loading Linux 2.6.32-5-amd64 ...'
linux /vmlinuz-2.6.32-5-amd64 root=/dev/mapper/hellish-root ro quiet
echo 'Loading initial ramdisk ...'
initrd /initrd.img-2.6.32-5-amd64
Ok, I’ve finally fixed it.
It appears that it wasn’t about the framebuffer in the end, but I simply could not put the script directly on /etc/rc.local, so instead, I create a /etc/rc.cuda with the script to load it, and /etc/rc.local calls that script.
