cuda_5.5.22_linux_64.run - Extraction failed.
I am trying to setup the cuda toolkit on a debian wheezy machine.
(I previously installed nvidia-cuda-toolkit from the debian repository, and it works, but it is grossly outdated).
However, I just cannot extract anything out of the run file:
root@thebeast:~/install# ./cuda_5.5.22_linux_64.run -verbose
Extraction failed.
Signal caught, cleaning up
I tried with -override, I tried with -tmpdir, I tried with -toolkit…always same result…
Oh…and the verbose flag doesn’t help much either…
Ok,
I found out the reason: not enough space on /tmp
Now, need to extract on another folder.
The -tmpdir=/root/tmp/ option is not working, I tried.
solution to extract:
export TMPDIR=/root/tmp
./cuda_5.5.22_linux_64.run -extract=/root/cuda
Try using sudo ./cuda_5.5.22_linux_64.run -tmpdir /root/tmp. Note the lack of the “=” in “-tmpdir /root/tmp”.
