I had 5.5 installed, but uninstalled to check on an error. Now when I try to reinstall, it fails, and the only error I can briefly see is something about “Visual Studio 2008 settings”. Is there an error log generated somewhere? It correctly identifies that there is no part of the toolkit installed, but it fails during the actual installation every time at the same place.
OS: Windows 7 64-bit
Can you please attach the screenshot about error?
That’s the problem. The error doesn’t stay up long enough for me to actually read it. It’s in the status message area right above the status bar indicating how much of the installation has finished. It’ll get to about 1/3 finished with “Installing CUDA Toolkit” then jump to the screen listing everything that was supposed to be installed, where it has “Failed” next to the CUDA toolkit and “Skipped” for everything else since it never got to them.
I’m pretty sure it’s failing at this section from CudaToolkit.nvi:
<custom phase="VS2008DevenvSetupInstall" action="VS2008DevenvSetupInstall" condition="VS2008Exists" installText="Configuring Visual Studio 2008 settings" uninstallText="Configuring Visual Studio 2008 settings">
<properties>
<string name="argument" value="/setup"/>
</properties>
</custom>
But I have no idea how to work around that, and I’ve tried the installation without VS2008 Express installed, which made no difference.
Try this:
Extract the installer with any LZMA extractor (looks like you’ve done that already based on your most recent comment).
From command line, run setup.exe with logging:
setup.exe -log:“C:\path\that\exists” -loglevel:6
Follow through the installation and attach the log files.
Andy,
Here you go. For what it’s worth, there a “file” in the unpacked folder that is titled PACKAGE_VALIDATION_FAILED as well.
The setup.exe log file is 7.5MB, so I’m uploading it here: http://www.qfpost.com/file/d?g=feanYK1Kc . The Rundll32.log is as follows:
0.104 | INFO: [system] 353@Nvidia::Logging::Logger::Logger : 2013-Aug-13 13:28:19 : Logging init OK. Using configuration from HKLM for DefaultProcess, for the RunDll32.EXE.
0.107 | DEBUG: [NVI2.DeferredDelete] 868@DeferredDeleteW : Waiting for C:\NVIDIA\CUDA\setup.exe 8848 to exit.
0.476 | DEBUG: [NVI2.DeferredDelete] 909@DeferredDeleteW : Deferred delete started.
0.489 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.controlpanel.{19aea78a-d1a5-4ef8-8158-a66d83b70eb7}".
0.579 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.581 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.584 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.586 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.588 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\control panel client".
0.590 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.593 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.595 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.598 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{47afe902-ac0c-46e0-9bea-c7fdd53817df}".
0.600 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.602 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.604 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.607 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.609 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.driver.{f4d529a3-d533-4085-b5ff-97a78228cf22}".
0.612 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.614 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.616 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.618 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.620 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.driver.{f4d529a3-d533-4085-b5ff-97a78228cf22}".
0.624 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.626 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.628 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.630 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.641 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{483308de-317e-4e23-8288-52125cc17875}".
0.643 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.645 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.649 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.651 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.653 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.gfexperience.{753f3f8b-d8d9-4220-9c17-eaed5cb62204}".
0.655 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.657 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.659 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.661 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.663 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files (x86)\nvidia corporation\nvidia geforce experience".
0.665 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files (x86)\nvidia corporation".
0.666 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files (x86)".
0.668 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.670 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{ccc36165-2554-47c6-8eae-78c4ee4df4bf}".
0.671 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.673 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.675 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.678 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.680 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.nvirusb.{48d4c802-b105-4165-ade6-860309d326ac}".
0.682 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.685 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.687 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.689 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.691 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.nvirusb.{48d4c802-b105-4165-ade6-860309d326ac}".
0.693 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.695 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.696 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.698 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.700 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{483308de-317e-4e23-8288-52125cc17875}".
0.702 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.704 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.706 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.709 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.712 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files (x86)\nvidia corporation\physx".
0.714 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files (x86)\nvidia corporation".
0.716 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files (x86)".
0.719 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.722 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.update.{9be8c976-edd5-4295-8db2-4bd46d49045b}".
0.725 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.727 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.730 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.732 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.735 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.update.{9be8c976-edd5-4295-8db2-4bd46d49045b}".
0.738 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.741 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.743 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.746 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.748 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{ccc36165-2554-47c6-8eae-78c4ee4df4bf}".
0.752 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.754 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.756 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.758 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.762 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\gfexperience.nvstreamsrv.{5b88c666-f78f-425c-abf2-421e40f7a68c}".
0.765 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.768 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.770 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.773 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.776 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\nvstreamsrv".
0.779 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.781 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.784 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.786 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{ccc36165-2554-47c6-8eae-78c4ee4df4bf}".
0.789 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.792 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.793 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.795 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.797 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\hdaudio.driver.{5a3aa450-c257-4bb7-bfe0-0db591dc332c}".
0.799 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.801 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.803 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.805 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.807 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\hdaudio.driver.{5a3aa450-c257-4bb7-bfe0-0db591dc332c}".
0.808 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.810 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.814 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.817 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.819 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{483308de-317e-4e23-8288-52125cc17875}".
0.821 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.824 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.827 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.830 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.832 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{483308de-317e-4e23-8288-52125cc17875}".
0.835 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.837 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.839 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.842 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.844 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{483308de-317e-4e23-8288-52125cc17875}".
0.847 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.848 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.850 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.853 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.856 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\nvidia.update.{9be828bf-91fc-48c2-b2cf-8859c6c1acc3}".
0.860 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.862 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.865 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.867 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.870 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files (x86)\nvidia corporation\nvidia update core".
0.872 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files (x86)\nvidia corporation".
0.875 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files (x86)".
0.878 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.880 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{ccc36165-2554-47c6-8eae-78c4ee4df4bf}".
0.883 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.886 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.888 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.891 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.893 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\virtualaudio.driver.{3ed1d5f9-c7ef-453e-ab2a-b01fc1a13da9}".
0.895 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.897 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.899 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.901 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.903 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\virtualaudio.driver.{3ed1d5f9-c7ef-453e-ab2a-b01fc1a13da9}".
0.905 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.907 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.909 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.912 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.914 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{ccc36165-2554-47c6-8eae-78c4ee4df4bf}".
0.916 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.918 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.920 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.923 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.926 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{483308de-317e-4e23-8288-52125cc17875}".
0.928 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.930 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.931 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.934 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.937 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.driver.{dee4f223-4187-4bff-a3b4-3a934ab2bfcb}".
0.939 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.940 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.943 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.945 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.948 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{390f9ffd-533d-4d24-87d9-eeea60cd9c51}".
0.950 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.952 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.954 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.956 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.959 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.update.{d97670e1-6d57-4064-8b59-24f34f1d53b9}".
0.962 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.963 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.966 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.969 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.970 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\hdaudio.driver.{5a3aa450-c257-4bb7-bfe0-0db591dc332c}".
0.972 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.974 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.977 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.979 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.982 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\nvidia.update.{2a974c34-29ad-496f-b26b-11b941bba7b1}".
0.984 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.986 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.988 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
0.990 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
0.993 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\cudasamples_5.5.{707db0fd-980a-411e-94c3-90bb5e9064e5}".
0.995 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
0.997 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
0.999 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.002 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.004 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\nsight.{36a09514-524f-4f55-8668-046c293274a9}".
1.006 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.009 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.011 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.013 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.015 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.gfexperience.{18422e27-df7a-47b4-88c9-819e05b4862f}".
1.018 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.020 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.022 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.024 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.027 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\cudadocumentation_5.5.{00f7a002-e494-4b88-8d7a-1db83e274f62}".
1.028 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.031 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.033 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.035 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.037 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.3dvision.{b105ede8-9a48-4be5-b5c2-62e4986f250a}".
1.040 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.043 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.045 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.047 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.050 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\vcredist.{05460e34-5f81-4ed9-a9ee-ab1b01ec0824}".
1.052 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.054 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.057 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.058 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.061 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.driver.{6aac36b3-8d59-449a-ac9c-dd19a18bc917}".
1.063 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.066 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.068 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.070 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.071 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{b572b56a-a3d1-4612-aabc-e93aee2345f2}".
1.074 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.077 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.078 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.080 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.083 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.nvirusb.{b1444f9b-49e3-4486-84d1-c3d553c07a25}".
1.085 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.087 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.089 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.091 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.093 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\cudatoolkit_5.5.{ad630af5-da3a-4ee0-a0bc-4a29a71c3aee}".
1.096 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.098 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.100 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.102 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.104 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\cudasamples_5.5.{707db0fd-980a-411e-94c3-90bb5e9064e5}".
1.105 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.107 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.108 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.110 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.112 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\nsight.{36a09514-524f-4f55-8668-046c293274a9}".
1.113 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.116 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.118 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.120 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.122 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\cudadocumentation_5.5.{00f7a002-e494-4b88-8d7a-1db83e274f62}".
1.125 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.127 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.128 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.130 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.133 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.3dvision.{cf1be3d9-14c0-48b8-8b1c-d7b61f565a57}".
1.134 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.136 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.138 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.139 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.141 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\vcredist.{05460e34-5f81-4ed9-a9ee-ab1b01ec0824}".
1.142 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.144 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.145 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.147 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.149 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.nvirusb.{b1444f9b-49e3-4486-84d1-c3d553c07a25}".
1.150 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.152 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.154 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.156 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.158 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{b572b56a-a3d1-4612-aabc-e93aee2345f2}".
1.160 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.161 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.163 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.164 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.166 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\cudatoolkit_5.5.{ad630af5-da3a-4ee0-a0bc-4a29a71c3aee}".
1.168 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.170 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.172 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.174 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.176 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\cudasamples_5.5.{707db0fd-980a-411e-94c3-90bb5e9064e5}".
1.178 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.180 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.182 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.183 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.185 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.driver.{6aac36b3-8d59-449a-ac9c-dd19a18bc917}".
1.186 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.188 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.190 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.192 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.194 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\nsight.{36a09514-524f-4f55-8668-046c293274a9}".
1.195 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.197 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.199 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.201 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.203 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\cudadocumentation_5.5.{00f7a002-e494-4b88-8d7a-1db83e274f62}".
1.204 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.206 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.208 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.211 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.212 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.3dvision.{cf1be3d9-14c0-48b8-8b1c-d7b61f565a57}".
1.214 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.215 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.218 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.220 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.222 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\vcredist.{05460e34-5f81-4ed9-a9ee-ab1b01ec0824}".
1.223 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.226 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.228 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.230 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.232 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\hdaudio.driver.{5a3aa450-c257-4bb7-bfe0-0db591dc332c}".
1.234 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.236 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.238 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.240 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.243 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{483308de-317e-4e23-8288-52125cc17875}".
1.244 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.246 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.248 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.249 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.252 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.nvirusb.{48d4c802-b105-4165-ade6-860309d326ac}".
1.254 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.256 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.257 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.260 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.262 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.driver.{f4d529a3-d533-4085-b5ff-97a78228cf22}".
1.264 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.265 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.268 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.270 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.272 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.3dvision.{e81bfb15-50d9-4da0-b74c-be94be9dd6b9}".
1.275 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.276 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.278 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.279 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.282 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.nvirusb.{48d4c802-b105-4165-ade6-860309d326ac}".
1.284 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.285 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.287 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.289 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.291 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\installer.{483308de-317e-4e23-8288-52125cc17875}".
1.293 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.294 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.296 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.298 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.300 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\hdaudio.driver.{5a3aa450-c257-4bb7-bfe0-0db591dc332c}".
1.302 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.303 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.305 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.307 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.309 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.driver.{f4d529a3-d533-4085-b5ff-97a78228cf22}".
1.310 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.312 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.314 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.316 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
1.318 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2\display.3dvision.{e81bfb15-50d9-4da0-b74c-be94be9dd6b9}".
1.320 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation\installer2".
1.322 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files\nvidia corporation".
1.324 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\program files".
1.325 | INFO: [NVI2.CEngineCache] 229@CEngineCache::PreservePath : Preserved path "c:\".
7.793 | INFO: [NVI2.DeferredDelete] 922@DeferredDeleteW : Deleting self as running deferred delete via C:\Users\BENMEE~1\AppData\Local\Temp\NVI2_29.DLL.
9.920 | DEBUG: [NVI2.DeferredDelete] 929@DeferredDeleteW : Deferred delete completed.
Well, I went through and found the error(s) myself. They are below:
291.077 | ERROR: [NVI2.NVCustomPhase] 239@CNVCustomPhase::InvokePhase : COM error: Exception {0x80070002 - The system cannot find the file specified.; File: NVCustomPhase.cpp; Line: 225}.
291.082 | INFO: [NVI2UI.CtrlClass] 162@CHtmlViewCtrlClass::BeginPaintParent : Frame clip = 0 , 0 , 592 , 360.
291.084 | ERROR: [NVI2.NVInstaller] 2059@CNVInstaller::InternalPerformInstall : Package "CUDAToolkit_5.5" failed with error: Exception {0x80070002 - The system cannot find the file specified.; File: PerformInstall.cpp; Line: 4003; Phase failure}.
2013-08-13 13:20:14.817 ( 291.126) | INFO: [system] 363@Nvidia::Logging::Logger::Logger : 2013-Aug-13 13:20:14 : Logging init OK. Using configuration from HKLM for DefaultProcess, for the setup.exe.
2013-08-13 13:20:14.820 ( 291.129) | DEBUG: [DisplayDriver.DisplayDriverExtSite] 700@CDisplayDriverExtSite::AfterInstallPackage : Package that finished is not Display.Driver , returning early.
291.121 | ERROR: [NVI2.NVInstaller] 2105@CNVInstaller::InternalPerformInstall : Failing at package "CUDAToolkit_5.5" failed with error: Exception {0x80070002 - The system cannot find the file specified.} - aborting install.
291.135 | ERROR: [NVI2.InstallThread] 54@CInstallThread::ThreadProc : Install failed - Exception {0x80070002 - The system cannot find the file specified.; File: PerformInstall.cpp; Line: 4003; Phase failure} - going to fail state.
291.137 | DEBUG: [NVI2.Installation] 97@CInstallationStepper::Present : Presenting "!InstallFailed".
Tried uninstalling all CUDA programs (including 5.0) and using DriverSweeper to clear out as much stuff as possble. Reinstalled graphics driver fine. Reinstalled CUDA 5.0 fine. CUDA 5.5 installation still fails.
Well, I got the installation to proceed by removing the following lines from CUDAToolkit.nvi in the CUDAToolkit subfolder:
<properties>
</properties>
</custom>
vvolkov
August 20, 2013, 1:54am
#11
I had a similar problem. Solved it making by reinstalling Windows.
g_l
March 5, 2015, 7:18pm
#12
Thanks @bmeekins , just had the same problem myself trying to install Cuda 5.5 on Win 8.1 (x64) with VC Express 2008 SP1 installed, and commenting out the VS2008DevenvSetupInstall section worked for me too.
Guess it doesn’t like the latest VC patches and/or some of the VC hotfixes I had installed.
