CUDA 5.5 VC++ redistributables installation error
I’m using Windows 8 and I have Visual Studio Professional 2012. I downloaded CUDA 5.5 from NVIDIA and when I tried to install it I get a message “Installtion could not complete” and the reason is because of VC++ redist contained in CUDA 5.5 installation package. So I installed all the packages seperatly. (i.e) NVIDIA graphics driver, NVIDIA NSIGHT for Visual Studio 2012 and I also have CUDA toolkit and CUDA Documentation. But the problem is I could not get CUDA 5.5 Samples as istallation fails before installing the samples.
If anyone knew how could I fix the installation error please reply. I also tried installion by removing all the VC++ redist but still no use. Now I have the latest VC++ redist.
Do anyone know what is the VC++ redist come with CUDA 5.5 package for 64bit ?
Please let me know
Hi darshan16,
Could you please attach installation logs from a clean installation:
  1. Extract the installer with any LZMA-capable extraction utility (such as 7z)
  2. Within a cmd window, run setup.exe like so:
    setup.exe -log:“C:\path\that\exists” -loglevel:6
  3. Attach the .log files that are created at “C:\path\that\exists”
Hi darshan16,
Have you had any chance to try the instructions above?
Here are the logs - I’ve been trying for days to get CUDA 6.0 to install. Have already unistalled VS2010 and tried, but keep getting these errors
51.133 | ERROR: [NVI2.NVAppPhase] 708@CNVAppPhase::InvokeApp : Executable failed.
51.137 | ERROR: [NVI2.NVInstaller] 1968@CNVInstaller::InternalPerformInstall : Package “VCRedist” failed with error: Exception {0xe0e00059; File: PerformInstall.cpp; Line: 3916; Phase failure}.
2014-05-06 16:44:37.758 ( 51.140) | INFO: [system] 391@Nvidia::Logging::Logger::Logger : 2014-May-06 16:44:37 : Logging init OK. Using configuration from HKLM for DefaultProcess, for the setup.exe.
2014-05-06 16:44:37.759 ( 51.141) | DEBUG: [DisplayDriver.DisplayDriverExtSite] 689@CDisplayDriverExtSite::AfterInstallPackage : Package that finished is not Display.Driver , returning early.
51.142 | ERROR: [NVI2.NVInstaller] 2014@CNVInstaller::InternalPerformInstall : Failing at package “VCRedist” failed with error: Exception {0xe0e00059} - aborting install.
51.146 | ERROR: [NVI2.InstallThread] 54@CInstallThread::ThreadProc : Install failed - Exception {0xe0e00059; File: PerformInstall.cpp; Line: 3916; Phase failure} - going to fail state.
I’m having same error installing CUDA 6.0 on Windows 7 Enterprise and Visual Studio 2012 premium.
222.470 |    ERROR: [NVI2.NVAppPhase] 708@CNVAppPhase::InvokeApp : Executable failed.
222.501 |    ERROR: [NVI2.NVInstaller] 1968@CNVInstaller::InternalPerformInstall : Package "VCRedist" failed with error: Exception {0xe0e00059; File: PerformInstall.cpp; Line: 3916; Phase failure}.
2014-07-21 14:59:48.780 ( 222.518) | DEBUG: [DisplayDriver.DisplayDriverExtSite] 689@CDisplayDriverExtSite::AfterInstallPackage : Package that finished is not Display.Driver , returning early.
222.509 | ERROR: [NVI2.NVInstaller] 2014@CNVInstaller::InternalPerformInstall : Failing at package “VCRedist” failed with error: Exception {0xe0e00059} - aborting install.
222.511 | ERROR: [NVI2.InstallThread] 54@CInstallThread::ThreadProc : Install failed - Exception {0xe0e00059; File: PerformInstall.cpp; Line: 3916; Phase failure} - going to fail state.
I’m having the same problem using Windows 8.1 on an HP Envy TouchSmart with a 740GTX. I’m trying to install the 6.0 toolkit, & getting the failure on VC++ Redistribs. I followed the procedure above to get a log, & have them to post, though I hesitate to post them here. Any advice on this front?
Same issue with toolkit 6.5 and windows 8.1 x64
Logs: http://rghost.ru/57939269
Part with error: http://pastie.org/9541372
Same issue, toolkit 6.5 windows 8.1 x64
obs.: first tried installing in my windows user folder - my name is accentuated.
Doesn’t work. Not the first time it fails (last year, another machine, same story).
Now a second try, using another admin account: partial installation (integrated with VS, but failed VC++ Redistributables, Samples…).
