I was trying to point my CUDA 5.5 (yes I am a crusty old version CUDA developer) to the SDK version of glew (wglew.h) in the SDK located C:\ProgramData\NVIDIA Corporation\CUDA Samples\v5.5\common\inc\GL
It appears that the version of glew supplied with the SDK does not support this. My download for CUDA 7.0 is going to take about 5 hours. When/If it completes will I find wglCreateContextAttribsARB in that version? What is status of Wrangler/glew library in SDK?
The question comes as I am trying to compile code which uses the latest wrangler api off the web. I decided to try and compile in an example from sdk into this project… then the fighting for which version of glew. SDK uses glew and freeglut from SDK, but app I am working with uses latest glew but not glut (freeglut).
What is best way to use glut, glew? From SDK or random bits of the internet? Clearly my 5.5 glew is a bit stale, but are newer SDKs including latest wrangler?
