CUDA 6.0 Ubuntu12.04.4 QuadroK2100M deviceQuery error
Hello. I’ve installed Cuda-6.0 on my Dell M4800 but I’m getting error when I want to run ./deviceQuery everytime. I’ve added pathes PATH and LD_LIBRARY_PATH to the ~/.bashrc file. ./deviceQuery output is;
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 3
-> initialization error
Result = FAIL
I’ve installed Cuda by the run file. NVIDIA driver version is 331.20
But when I run the ./deviceQueryDrv it’s showing me the normal ./deviceQuery output;
./deviceQueryDrv Starting…
CUDA Device Query (Driver API) statically linked version
Detected 1 CUDA Capable device(s)
Device 0: “Quadro K2100M”
CUDA Driver Version: 6.0
CUDA Capability Major/Minor version number: 3.0
Total amount of global memory: 2048 MBytes (2147287040 bytes)
( 3) Multiprocessors, (192) CUDA Cores/MP: 576 CUDA Cores
GPU Clock rate: 667 MHz (0.67 GHz)
Memory Clock rate: 1504 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 262144 bytes
Max Texture Dimension Sizes 1D=(65536) 2D=(65536, 65536) 3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Texture alignment: 512 bytes
Maximum memory pitch: 2147483647 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Concurrent kernel execution: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device PCI Bus ID / PCI location ID: 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Result = PASS
I’m not understanding this results. Thanks.
