I want use cuda 6.5 with opencv4tegra on my notebook with Ubuntu 14.04 and GT 540M Device.
For the installation i have used this guide
http://developer.download.nvidia.com/embedded/OpenCV/L4T_21.1/README.txt
I downloaded it from here
cuda-repo-ubuntu1404-6-5-prod_6.5-19_amd64.deb + libopencv4tegra-repo_ubuntu1404_2.4.10.1_amd64.deb
But I do not use the 340.29 driver, which is included in cuda 6.5, because this causes a black screen after installation. I installed 352.63 driver, this is included in CUDA 7.5.
The CUDA samples can be compiled and run successfully.
deviceQuery shows:
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GeForce GT 540M"
CUDA Driver Version / Runtime Version 7.5 / 6.5
CUDA Capability Major/Minor version number: 2.1
Total amount of global memory: 2048 MBytes (2147155968 bytes)
( 2) Multiprocessors, ( 48) CUDA Cores/MP: 96 CUDA Cores
GPU Clock rate: 1344 MHz (1.34 GHz)
Memory Clock rate: 900 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 131072 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65535), 3D=(2048, 2048, 2048)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per multiprocessor: 1536
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (65535, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device PCI Bus ID / PCI location ID: 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 7.5, CUDA Runtime Version = 6.5, NumDevs = 1, Device0 = GeForce GT 540M
Result = PASS
Next, I wanted to use opencv with this simple example:
#include <iostream>
#include "opencv2/opencv.hpp"
#include "opencv2/gpu/gpu.hpp"
int main (int argc, char* argv[])
cv::Mat src_host = cv::imread("/home/obelov/file.png", CV_LOAD_IMAGE_GRAYSCALE);
cv::gpu::GpuMat dst, src;
src.upload(src_host);
cv::gpu::threshold(src, dst, 128.0, 255.0, CV_THRESH_BINARY); // here comes the error
cv::Mat result_host(dst);
cv::imshow("Result", result_host);
cv::waitKey();
return 0;
this code is successfully compiled, but if you want to run this, comes an error
OpenCV Error: Gpu API call (invalid device function ) in call, file /hdd/buildbot/slaves/slave_ubuntu14/54-O4T-Ubuntu14/opencv/modules/gpu/include/opencv2/gpu/device/detail/transform_detail.hpp, line 361
terminate called after throwing an instance of 'cv::Exception'
what(): /hdd/buildbot/slaves/slave_ubuntu14/54-O4T-Ubuntu14/opencv/modules/gpu/include/opencv2/gpu/device/detail/transform_detail.hpp:361: error: (-217) invalid device function in function call
Could this error be due to the driver 352.63? Because CUDA 6.5 uses a 340.29?
But, CUDA without using OpenCV works great!
