Hi all
My system is i7, 16 GB with GTX630 installed. Cuda 5 worked but 6 installation failed. I have removed 5 and re-install 6, but same error. There is no clue of what happened but it just bombed at Cuda toolkit all the time. I extracted the files into a temp dir and use command line setup ( got it from this mailing list as well) and following is the lone error from the log.
ERROR: [NVI2.NVInstaller] 235@CNVInstaller::PerformSteps : Installation failed with error Exception {0x8007010b - The directory name is invalid.; File: SimpleThread.h; Line: 228}.
Any gives?
thanks in advance
SteveT
