It isn’t feasible for me to downgrade gcc on my system (other packages require 4.8.2.) So, I am trying to install via the .rpm/yum repository. I’m stuck on getting the kernel module installed.
I see two packages: nvidia-kmod from the cuda repository and kmod-nvidia from the rpmfusion repository. Neither seems to work. I have installed the former but X complains that it can’t load the driver on startup. If I do an ‘lsmod | grep nv’, nothing shows up.
The nvidia-kmod package is 331.62 (from the cuda repo) whereas the xorg-x11-drv-nvidia package is 331.67 (from rpmfusion-nonfree-updates). Are these compatible? This is just what the repo gave me with the cuda-6-0 metapackage. What is the connection between these two packages and are both required?
I think I solved it. There were lingering xorg-x11-drv-nvidia-* packages from rpmfusion with a higher version number than what’s required by the cuda-6-0 metapackage. yum tries to get the most recent version of each required package and the ones it really needed were obsoleted by rpmfusion’s copies. Removing all the xorg-x11-drv-nvidia packages followed by disabling rpmfusion and reinstalling the cuda-6-0 metapackage fixed it.
