CUDA 7.5 + OSX 10.10.5 Yosemite fatal error: 'memory' file not found
Hi everybody, I am trying to use cuda toolkit, i was following instructions, and when I tried to build samples, it gave me an error. This error is for 1_Utilities/deviceQuery:
#include <memory>
My thoughts that I am missing some standard paths somewhere, but I don’t really know how to fix this. Anybody have any ideas or had this problem before?
CUDA 7.5
OSX 10.10.5
Xcode 6.4 + command line tools
p.s. originally wanted to build opencv3 with gnu support, but got the same error, then went to check if samples work.
Complete Log:
$ make
/Developer/NVIDIA/CUDA-7.5/bin/nvcc -ccbin clang++ -I../../common/inc  -m64  -Xcompiler -arch -Xcompiler x86_64  -gencode arch=compute_20,code=sm_20 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_52,code=compute_52 -o deviceQuery.o -c deviceQuery.cpp
/usr/include/module.map:1:25: warning: unknown attribute 'extern_c'
      [-Wignored-attributes]
module Darwin [system] [extern_c] {
/usr/include/module.map:1561:21: warning: unknown attribute 'extern_c'
module os [system] [extern_c] {
/usr/include/module.map:1577:26: warning: unknown attribute 'extern_c'
module libkern [system] [extern_c] {
/usr/include/module.map:1602:23: warning: unknown attribute 'extern_c'
module ldap [system] [extern_c] {
/usr/include/module.map:1635:23: warning: unknown attribute 'extern_c'
module krb5 [system] [extern_c] {
/usr/include/module.map:1662:22: warning: unknown attribute 'extern_c'
module XPC [system] [extern_c] {
deviceQuery.cpp:16:10: fatal error: 'memory' file not found
#include <memory>
